headlight won't come uo
Old Aug 27, 2006 | 08:58 AM
pieplow's Avatar
pieplow
Default headlight won't come uo
my left headlight started to not pop up recently. i had the system set to automatically turn-on (twilight) and when it wouldn't work, i would turn the twilight off, manually turn-on the headlights, and it would immediately work. it was happening about 10-15% of the time. now it seems to be stuck permanently. any ideas of a quick and simple fix? i have a 2000.
Old Aug 27, 2006 | 09:12 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Normally the cause of the issue is the gears (they are plastic OEM).
A permeate fix is to use the brass gears.
I cannot find the site for ordering, but someone will chime in.
Old Aug 27, 2006 | 09:17 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
Found it:
http://www.rodneydickman.com/retail.html
Good luck
Damn - this is my 10,000th POST - WOW>
Old Aug 27, 2006 | 09:27 AM
DeeGee's Avatar
DeeGee
The headlight gear problem is normally accompanied by a grinding sound when the motor is operating. It's caused by the stripped gear failing to connect properly with the ring gear.
Yours sounds a bit more unusual than the normal problem. If the lights operate normally at all times when you select manually using the headlight switch but not at all when twilight sentinel is selected it soulds like an issue with the sentinel. The strange thing is that TS should be overridden by the manual switch.
JC in XTC5 has a lot of experience with these motors. He may chime up.
Old Aug 27, 2006 | 09:28 AM
DeeGee's Avatar
DeeGee
Originally Posted by AC54ME
Found it:
Good luck
Congrats and thanks for all your contributions
Old Aug 27, 2006 | 09:49 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Found it:
Good luck
Way to Go.
Old Aug 27, 2006 | 10:03 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Just installed a set of brass gears that I bought from Rodney. Easy install with good directions. Should solve your problem.
Old Aug 27, 2006 | 10:06 PM
SRQC5's Avatar
SRQC5
buy the bracket as well or the epoxy will eventually come loose and youll be back where you started
Old Aug 27, 2006 | 10:43 PM
silverbullit99's Avatar
silverbullit99
My is starting to do the same thing,, left side,, I usually open the hood and turn the manual know about a turn. Then try the lights it usually works for a few more flips after that. It has to be the gears,, from what everyone advises the brass ones is the way to go. Think I'll make that my winter project. I'll probably replace both. Is there any how to tips on this ,, ?
Old Aug 27, 2006 | 11:45 PM
napacruzerc5's Avatar
napacruzerc5
Once you get it fixed I would also turn off the Twilight Sentinel. I hate it when the lights come up for just driving out of the garage. And I think I know by now when to turn on the headlights when needed.
Old Aug 28, 2006 | 01:13 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i bet you it is the little rubber bits that are inside the gear that is the culprit and not necessarily the gears.
Old Aug 28, 2006 | 09:03 AM
rkort's Avatar
rkort
Default the one eye
mine is doing nothing, i just here the motor turnin, not even the manual is working, is this still the gear.
Old Aug 28, 2006 | 09:26 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Might mean that your gear is completely worn down. Here is the link with the how-to info
http://forums.corvetteforum.com/show...DIY&forum_id=1
Just did this myself last week and it solved my headlight problems. Hope this helps.
To headlight won't come uo
