Shifting Question????
Old Aug 28, 2006 | 06:01 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Shifting Question????
Newbie question - is it bad to shift from 6th to 4th and stepping into it? Also, I shift aggressively through the gears, is it bad on the car versus shifting slow.
Thanks,
Tony P
Old Aug 28, 2006 | 06:06 PM
Frozenfire's Avatar
Frozenfire
On the interstates I've had to make sudden downshifts to accommodate changes in traffic. No adverse results I'm aware of. I try not to make a habit of doing that though.
Old Aug 28, 2006 | 09:01 PM
SRQC5's Avatar
SRQC5
what is this 6th gear you speak of???
Old Aug 28, 2006 | 09:52 PM
C5Jim's Avatar
C5Jim
Go for it.
Its redline you should be worried about not which gear, although going from 6th to 1st may put you in the red.
The car was designed to be pounced, so pounce it and enjoy it.
Old Aug 28, 2006 | 09:54 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Old Aug 28, 2006 | 09:55 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Give it some throttle when you go from 6th to 4th. Other than that, no problems!
Old Aug 28, 2006 | 09:58 PM
gpracer1's Avatar
gpracer1
Happens to me all the time. Just cruisin along in 5th miding my own business and then some fart can tries to shake rice all over me and I have to downshift into second.....at the track.
Old Aug 29, 2006 | 12:18 AM
slwhite's Avatar
slwhite
Are you kidding? I frequently shift from 6th to 3rd if I want to do some serious passing. Just make sure you have the RPM matched up.
Old Aug 29, 2006 | 12:37 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Really wakes up the Corsas!
Old Aug 29, 2006 | 12:51 AM
Gothikka's Avatar
Gothikka
If that hurts the car my car would be dead by now
"what is this 6th gear you speak of" rofl...thats funny. I never use mine either.
All kidding aside. a downshift from 6th to 4th will do no harm to your car as long as you dont hit the red line. Might be a little hard on the neck though.
Old Aug 29, 2006 | 07:32 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
6th gear is for cruising only at interstate speeds. If you have all day to pass you can creep by in 6th but need to downshift if you want to "make a move." Hard shifitng can cause you to bend a shift fork.
DBD
Old Aug 29, 2006 | 08:06 AM
rtsb's Avatar
rtsb
Default I know what 6th is used for
I use it to go to work every night and come home every morning and watch every one go by me real fast and they all just stare at me probably wanting to know why I'm doing 62 with the cruise on.Well sit in one and enjoy the ride I'm in no hurry to get home just to go to bed I love this car I've had it a month and love it.................
Old Aug 29, 2006 | 10:39 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Match the revs with the gearing you going to so the clutch and transmission dont take the shock and wear that will occur by just slamming it into gear and stepping on it!
Old Aug 29, 2006 | 12:17 PM
No problem shifting like that that I know of. I do it every now and then when on the highway for passing.
Old Aug 29, 2006 | 12:53 PM
SavPrato's Avatar
SavPrato
Should be OK as long as you match the revs and don't redline.
Old Aug 29, 2006 | 01:34 PM
MiamiCowboy's Avatar
MiamiCowboy
You need to rev match your engine speed to the reduction in gearing. If you blip the throttle as you down shift you should be able to get a smooth transfer without any jolt to the drive train. The tachometer is actually something that you can use in this case.
Old Aug 30, 2006 | 11:12 AM
MedChoice Tony
Default Dumb Question
"You need to rev match your engine speed to the reduction in gearing" can someone explain in detail what speeds/rpms this is?
Thanks,
Tony P
Old Aug 30, 2006 | 11:18 AM
c5coast's Avatar
c5coast
Check this out
http://www.waycoolinc.com/z3/essenti...e/shifting.htm
Old Aug 30, 2006 | 11:34 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
unreal.... no need to match the revs!!! we arent driving semis.
60mph.... 5th gear...... downshift into 2nd.... do it all the time.
To Shifting Question????
