AC barely blows
Old Aug 30, 2006 | 05:10 PM
beefaronie's Avatar
beefaronie
Default AC barely blows
When it is on high I cant really even feel the air displacement get to my face. The air is fairly cold, just not much airflow. Any suggestions?
Old Aug 30, 2006 | 05:23 PM
JohnsC5's Avatar
JohnsC5
There was another thred about this very recently. Seems like the usual cause is a vacumn leak which doesn't allow the ducts to open fully. Someone else will probably chime in here and explain it better.
Old Aug 30, 2006 | 06:19 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
the vacuum line that folks have found is located under the battery, and under the battery holder. The theory has been that these cars had experienced a leaky battery, and the acid has been eating away at the vacuum line (as well as possibly other lines and wires that are conveniently located under the battery).
Old Aug 30, 2006 | 06:26 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
The title reminded me of an ex-GF... same initials!
Anyway, hope you get the issue fixed. Check you cowl area as well... make sure the intake isn't blocked.
Old Aug 30, 2006 | 06:34 PM
GR8-LIFE's Avatar
GR8-LIFE
I had a similar problem in the 1st year of my car. Turned out to be a hose that been erroded as a cause of battery acid from the notorious AC Delco leaking-battery issue
Old Aug 30, 2006 | 09:14 PM
acerider's Avatar
acerider
Do you get a cold spot in the middle of your windshield? Do your vents route correctly when you change the mode settings? If they don't, check the vacuum tube at the rear of the manifold next to the firewall. It might've come disconnected. This will also affect the airflow because the system is pushing air through all the vents at once, instead of just the ones selected by the mode switch. Good Luck!
Old Aug 30, 2006 | 11:54 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If it doesn't blow - does that mean it sucks?
Fan motor, fuses for the fan motor, obstructions? Is there any kind of error code on the DIC?
Old Aug 31, 2006 | 07:51 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
I was thinking the same thing... In my case her name was Amanda....
Old Aug 31, 2006 | 08:27 AM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Try closing the passenger vents...
Old Aug 31, 2006 | 09:20 AM
Oldvetter's Avatar
Oldvetter
Have you replaced your oil pressure sensor recently? If so you (they?) probably did not replace the "soda straw" size vacuum line that controls the HVAC doors. Check if the "little" air flow changes to the correct location (defrost, A/C, heat) when you select it. If it doesn't, no vacuum supply (or a leak) is the cause. Good luck!
Old Aug 31, 2006 | 10:16 AM
beefaronie's Avatar
beefaronie
How do I get to this line to check it? And which one is it?
When I turn on the other modes it routes correctly, in fact sometimes I turn on defrost instead because I think it blows air harder than the AC front vents.
I have not checked the fuses yet, and havent checked the codes either. I should probably do this, what kind of codes would I be looking for?
Is this the same line that acerider was saying is at the rear of the maifold? The air flow does change locations and I think it actually blows a bit harder in the other vents (ie defrost and floor). I have owned the car 2 years and never had the oil pressure sensor replaced, but that does not mean the previous owner did not. It has been this way the whole time I have owned it.
Old Aug 31, 2006 | 10:21 AM
blacksedan87
Here are the DIC codes that pertain to the HVAC systems.....
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
I was looking in my service manual last night - and if there is a code, it will make it a lot easier to trouble shoot....
Old Aug 31, 2006 | 10:36 AM
beefaronie's Avatar
beefaronie
OK. The codes I have are:
U1160
B2285
U1096
U1064 <------ on your list
U1016
Most if not all had an H after them. Also, I have cleared my codes out a few times since owning the vehicle.
Old Aug 31, 2006 | 10:38 AM
Kale's Avatar
Kale
Have you changed your cabin air filter? My wife's saturn barely trickled, and I changed that sucker, and its a tornado in that car now.
These should be replaced once a year.
(disclaimer: I don't know if the vette has a cabin air filter, but I can't imagine it doesn't. All modern cars I know of do.)
Old Aug 31, 2006 | 10:43 AM
beefaronie's Avatar
beefaronie
Never heard of it. Does anyone know about this, and where it is located???
PS nice avatar..... Two in the goo and one in the poo
Old Aug 31, 2006 | 11:56 AM
HollywoodFRC's Avatar
HollywoodFRC
Default HVAC Issues
No cabin air filter in C5s. Also, check your vacum system under the battery tray. Source of vacum is MAP sensor on back of intake manifold(You can't see this without sliding the intake manifold forward). This supply line is buried in one of (Top one for my '99 FRC) wiring harness that passes through the battery compartment to a check valve behind the passenger fender near the door. Supply line comes off the check valve through the wiring harness that enters the firewall behind the battery. You have to open the wiring harnesses and find these lines to make sure they are not damaged. They look like large wires but are black plastic. It takes very little battery acid to damage these lines. I had the problem and spliced in new lines, switched to an OPTIMA, sleeved rubber fuel line over the vacum lines for added protection. All works fine now. Good luck! easy DIY project.
Old Aug 31, 2006 | 02:09 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Try this link. I did this to fix mine. Zuti
http://forums.corvetteforum.com/show....php?t=1458727
To AC barely blows
Old Aug 31, 2006 | 02:52 PM
beefaronie's Avatar
beefaronie
Nice write up. I will have to check that. How does the battery tray come out?
Old Aug 31, 2006 | 03:12 PM
Zuti's Avatar
Zuti
CI 6-8-9 Veteran
Just pull the battery and there are three or four bolts on the inside of the center of the tray. Just back them out and it comes right off. About a five minute job total including battery removal. Zuti
Old Aug 31, 2006 | 04:03 PM
c5vette_dallas's Avatar
c5vette_dallas
sounds like ur hamster is dieing....go to petsmart and get a new one...put him in the left air conditioning vent..he will find his way to the wheel.. kill the almost dead hamster. drop him through a hole in the floor to the road and ur AC will blow again
