Center Console won't open
Old Aug 31, 2006 | 01:57 PM
Mikev078's Avatar
Mikev078
Default Center Console won't open
Anyone else have problems with the center console only opening up like an inch. I've looked all over to see if something was getting caught, but not finding anything. Do these have any history of bad hinges or something like that by chance?
This is on my '03 50th coupe.
Old Aug 31, 2006 | 02:00 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Pull it towards you when lifting, then oil the hinges.
It's a double knuckle hinge so that it doesn't hit the e brake handle when it's up.
Old Aug 31, 2006 | 02:04 PM
LV_2_XLR8's Avatar
LV_2_XLR8
There's nothing wrong with the console. They are all hard to open until you get the hang of it. Just open it until it until it sticks, then pull the top toward you while lifting. Don't be afraid to force it. It will open all the way.
OOPS! I must have been typing while madeouttaglass was posting...
Old Aug 31, 2006 | 02:07 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Oil the hinges and it will be easy.
Old Aug 31, 2006 | 02:10 PM
steve8's Avatar
steve8
A little shot of wd-40 will work wonders.
Old Aug 31, 2006 | 02:37 PM
CVG323's Avatar
CVG323
cant believe no one has said this,
is it unlocked? check if its unlocked.
keyhole is on driver side by TCS button
Old Aug 31, 2006 | 03:09 PM
Mikev078's Avatar
Mikev078
Trust me, checking to see if it was locked was the first thing, hehe.
I've tried using a bit of force, but it wouldn't budge past 1-2" I didn't go much further out of fear of breaking it.
I'll try pulling towards me when I get off from work.
Thanks everyone
Old Aug 31, 2006 | 03:22 PM
Humy's Avatar
Humy
it is tricky, I don't think you will need to oil it... just pull the arm rest where it is hinged towards you slightly and it will open to 90 degrees
you'll laugh at yourself when you figure it out, I sure did
Old Aug 31, 2006 | 03:27 PM
dndrsn's Avatar
dndrsn
Mine was hard to open at first and I did the pull it toward you thing to open it. Finally I oiled the hinges and now it opens up easily, no pulling or anything, it just opens up like you would think it should. Lookie HERE and see.
Old Sep 1, 2006 | 12:54 AM
I thought there was something wrong with it when I first got my car too, but its designed that way.
Old Sep 1, 2006 | 05:07 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I didn't say it because he said in his original post he can already open it about an inch which he wouldn't be able to do if it were locked. However, I agree with all the above on the opening procedure.
To Center Console won't open
