[Z06] Brake fluid for clutch
Question for Roger..I noticed a while back on changing out clutch fluid that the picture of the clutch resv. didn't have the black rubbber diaphram in it. When I checked mine it has the diaphram. My question is can you leave the diaphram out and to what level do you re fill it accounting for heat expantion..
best place oil change in DFW
need to change the oil after trip to carlisle, best place in DFW area to have done RIGHT without damage to lowered car. Thanks guys, carlisle was awesome as usual.
Mike
Mike
Here are my usual three threads for ref:
Clutch Pedal Woes--Fluid Impact
C6 Clutch Hydraulic Fluid--the Chevy Spec
Clutch Pedal Woes--Fluid Changing Kit
Ranger
Clutch fluid.
Ranger, thanks for the replly. I think you more than answered my question. I wasn't sure about the surge damper, but it will stay where it is .. Thanks again..
If nothing else, the diaphragm provides a seal to the lid and reduces the fluid contact with moisture.
You fill it up to the step on the inside of the reservoir, and I use the GM clutch fluid instead of regular brake fluid. The GM fluid is supposed to have additional additives to reduce friction.
