Help with the C5 headlight gear instructions
Thank you
Rodney Dickman
Rodney Dickman's Auto Acc's
Web page: www.rodneydickman.com
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax(262) 835-9575
Thank you
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Your idea to modify the instructions would be helpful - IMO, pictures would be as good or better than any CAD drawings.
My $0.02 on areas to drill down on:
1 - The brass washer: Your instructions indicate to mount the brass washer on the long shaft (drive shaft) of the assembly. However, since the shaft mounts one way for the driver side vs the pass. side, it can be confusing. It might be helpful to detail the install for the pass. side to show the brass washer going on, then turning the gear/shaft over for install.
2 - The metal bracket.. Again, more detail on the fact that on the driver side, it goes on the shaft side and on the passenger side the bracket goes on the 'stub' side. Perhaps it's obvious since that's where the covers are oriented, but if you don't do a lot of this, it could be helpful.
It's a very well thought out kit - The inclusion of the epoxy and the lube is a great touch. The addition of some pics to the combined directions will make life easier for mod-noobs like me
You may want to try this software - free trial: http://www.smartdraw.com/specials/ca...ng.asp?id=1134
Side bar question - after the install, it seems that the driver side headlight comes up a tad bit slower than the passenger side. Lowering takes the same time. The gear was turning fine by hand, so it doesn't seem to be getting any extra drag.. Any ideas on what might be causing that?
Thanks,
Chris
