Convertible hatch release button
Old Sep 3, 2006 | 08:44 PM
Wbarnes352's Avatar
Wbarnes352
Cruising
Default Convertible hatch release button
Having problems with the release button required to tuck away the top. Sometimes it work, sometimes it doesn't.
2001 yellow convertible.
Any suggestions.
Need help.
Winston
Old Sep 3, 2006 | 09:19 PM
steve8's Avatar
steve8
No problems with my 04, but I have heard of switch prolems with some earlier models.
Old Sep 3, 2006 | 09:24 PM
D2Brewing's Avatar
D2Brewing
If the doors are locked (ie the top is already down), the release won't work. Just a thought...
Old Sep 3, 2006 | 10:38 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
And a good thought at that. It also won't work if the trunk lid is popped to prevent damage.
Old Sep 3, 2006 | 11:26 PM
vectorz's Avatar
vectorz
I've had mine go out twice. Had to replace the entire latch unit.
Old Sep 3, 2006 | 11:34 PM
Frozenfire's Avatar
Frozenfire
Also, if the trunk is open, the chime will sound as well. Since the toneau release button's wiring is exposed, make sure there's no damage to it.
Old Sep 4, 2006 | 09:01 AM
Dr. Dan's Avatar
Dr. Dan
Winston,
I have the same problem at times...Here is the advice that I was given. So far no more issues (Touch wood)
http://forums.corvetteforum.com/show....php?t=1458306
Old Sep 5, 2006 | 11:52 AM
Wbarnes352's Avatar
Wbarnes352
Cruising
Default Having problems with the release button required to tuck away the top. Sometimes it w
Drove corvette to dealer this morning. Demonstrated that hatch would not release. Amazing, hatch released on every attempt. He said to bring back when there is a problem. I explained the problem was intermittant.
Spoiler
Thanks for all the replies.
Winston
Old Sep 5, 2006 | 12:22 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Hi Winston, When you say it doesn't work all the time, can you be more specific. When you press the button do you hear the latches release, or sometimes do you not hear anything? If you alwys hear the latches release them it may be a problem with the latches, if you do not always hear the latches release then it may be the button or a wiring problem.
Old Sep 5, 2006 | 03:25 PM
jgentle's Avatar
jgentle
Not to be a wise ***, but it took a few times for me to "get it" that the latch wouldn't work with the ignition "on" or turned to acc. Hope this helps.
Jack
Old Sep 5, 2006 | 11:43 PM
Wbarnes352's Avatar
Wbarnes352
Cruising
Still working ok. When there was a problem, I did not always hear the latches release.
Counting my blessings thus far.
Winston
Old Sep 5, 2006 | 11:48 PM
Wbarnes352's Avatar
Wbarnes352
Cruising
Jack
Ignition and acc off. When there was a problem tried several suggestions, none worked. Went to dealer, no problem existed during my demo of problem. He did smile when I mentioned the word intermittant
Winston
To Convertible hatch release button
