Timing or dirty injectors????
Old Sep 3, 2006 | 11:43 PM
mcmtac14's Avatar
mcmtac14
Default Timing or dirty injectors????
Hey all,
My 2002 coupe has a starnge problem.... when I hit the gas pedal to accelerate hard I get a pinging sound... like low octane or timing is out. My vette has been doing this for about two weeks now .... it runs great otherwise.
I really sounds like low octane gas but I ONLY use super premium and have tried several brands / locations to see if it was a certain fuels... no change.
Could it be:
1. Dirty injectors - it runs great except at heavy or WOT. Milage is good, 19.5 city 22.5 highway.
2. Air filter - just a hunch - my car has 18K on it and the filter was changed at 9K.
3. Timing - I have not had to even think about a car being out of proper timing since I had my 69 427 / 435. I don't even know what we do now....
Please let me know what to check out before I go to the Chevy store and go through the Vette tax dance!
Thanks,
mcmtac14
Old Sep 4, 2006 | 12:01 AM
jrose7004's Avatar
jrose7004
Sounds to me that you're not getting the octane you're paying for!
Old Sep 4, 2006 | 12:26 AM
mcmtac14's Avatar
mcmtac14
I hear ya but I have tried MANY stations in penna. and new jersey in the last few weeks..... I is pinging like that though!
Old Sep 4, 2006 | 01:14 AM
muncie21's Avatar
muncie21
Check for an air leak around the air bridge. If it isn't fuel related, then you are getting too much air.
Old Sep 4, 2006 | 01:33 AM
keliente's Avatar
keliente
Today we tune cars via software to the PCM to fix timing issues.
Honestly I think you just got a bad tank of gas seeing as this just started happening. I would run that tank out, fill it with new stuff and see how that goes.
Still pinging? May want to try a catch can, all years of car can benefit. The car tends to ingest a bit of oil that is running through PCV right into the intake manifold. Consuming oil = diluting a/f ratio, thus making for a lean condition and the dreaded spark knock. A catch can will catch that small bit of oil to keep your car from feasting on it
A tune can't hurt either - and you would probably gain some hp/tq from a tune also. At the very least, datalogging the car on a dyno run/street run will show exactly where that knock is, and from there you could pull some timing out to keep it from pinging. When I first got mine it would ping at low rpm's, high load (like accelerating in 6th). Scanned, pulled a couple degrees, we're cool now.
Old Sep 4, 2006 | 07:42 AM
hardtop's Avatar
hardtop
All gas is not created equal.
I know you said you tried different gas and different states. I had the same problem with pinging. Although I use the highest octane available, I sometimes went to a local, non-national name gas station. One in particular comes to mind El Cheapo. Started getting the pinging even though I didn't go there regular. I don't try to save a penny on gas any longer. I only go to stations that have a national reputation. They use detergents and have years of experience and a reputation to uphold. Also, try running Techron through there and see if it gets any better.
And stay away from Wawa for a while too. I never had a problem with them but maybe they changed their formula.
Old Sep 4, 2006 | 09:05 AM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I had the same issue since the car was new, so no chance of carbon build up on the head to slightly increase compression ratio. I finally got it fixed when I had the car dyno and tuned, they retarded the timing slightly and all is well.
Old Sep 5, 2006 | 03:41 PM
mcmtac14's Avatar
mcmtac14
Default Has anybody used the pour in the take injector cleaners?
I don't think it's a matter of bad gas as I use super premium from only the majors.... Sunoco, BP and Shell... I wanted to know if anyone has good or bad experiences with the additives that you buy to add to your tank every so ofet...
Thanks all!
mcmtac
Old Sep 5, 2006 | 04:03 PM
jrose7004's Avatar
jrose7004
I run Berrymans Chem Tool through all of my cars a couple of times a year.
To Timing or dirty injectors????
