Holy #$%!! - Not Again!!!
Old Sep 4, 2006 | 03:27 PM
JiminFL's Avatar
JiminFL
Default Holy #$%!! - Not Again!!!
I just had the nose replaced in late June after having a piece of retread fly up and smack it.
This morning on our way to the beach to see the sun rise, we're listening to xm and tooling along with the cruise on, and WHAMMM!!!
From nowhere a complete wheel and tire are laying in the middle of my lane and there isn't even time to hit the brakes or swerve before I took it right down the center. Luckily we didn't lose control or tear a wheel clean off, and we're VERY fortunate it went under instead of over the car. I'm still reeling in my head as we encounter what looked like the fender that used to surround this tire, also just about right down the middle of the undercarriage.
Dena and I are fine, and I pulled off about 200 yards ahead to check out the car. Bear in mind it's still not yet 6:30, and this stretch of I-4 has no streetlights, so it's quite dark. I expected to see all sorts of fluids draining out, and I had to look quickly to avoid having my head under the car on the shoulder there with traffic approaching. From what I could see there was only the expected water dripping from the A/C, and when I stopped there was no steam, oil pressure was steady, the e-brake worked, and the brakes held firm.
As I checked out the car and worked to break free the side of the center air flap that was still attached and causing it to drag straight back near the RF wheel, at least 4 or 5 other cars stopped either back closer to the spot where the wheel was or just past me. Once I got the air dam removed and decided nothing was dragging or draining, I drove to the exit just ahead and went to a gas station to wait for the trooper and see what things looked like in better light.
Looks like I'll need a new nose, front plate cover, possibly R brake duct, front subframe, air dam pieces, and a RF inner fender liner, plus some paint, so far . I'll post pics when I get back to work tomorrow and grab a camera, but it looks like I'll be in a #$^@%$ rental again for a while, and probably won't have the vette back in time for the trip to the Petit Le Mans at Road Atlanta.
Once this repair is done, I'm pulling the hardbar and harnesses out, putting the stock exhaust back on, and it's time to order the 07, I think.
This car has done great at protecting me when it had to and providing some really fun track days when it got to play , but I think somebody's trying to tell me it's time for the C6.
Old Sep 4, 2006 | 03:33 PM
TonyC5's Avatar
TonyC5
Man, I'll tell you, what a bunch of bad luck... BUT, you all are ok, that is all that matters...
Get the car fixed and let us see the new C6 when you get her...
Old Sep 4, 2006 | 03:37 PM
ja03c5's Avatar
ja03c5
Wow that stinks! Glad you're ok!
Old Sep 4, 2006 | 03:42 PM
shakainc's Avatar
shakainc
What bad luck. Good to see your okay. Post pics of the new C6 if you get it.
Old Sep 4, 2006 | 03:46 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
That sucks...
Glad you are ok
Peace
Willfulone
Old Sep 4, 2006 | 03:53 PM
vpunteney's Avatar
vpunteney
I'm so sorry to hear about this, but very glad you are OK. We had a simi go right next to us last summer and I thought we just got bombed. After I changed my shorts and pulled remaining leather out of my azz, we continued down the road.
Vinnie
Old Sep 4, 2006 | 04:11 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
You had a complete tire AND wheel go under your car from front to back????????
You are lucky that you were able to drive the car safely through that. Maybe more than lucky but a very good and cool driver...
That sounds almost impossible to a car that sits 4" off the ground.
Glad you two are ok...
Old Sep 4, 2006 | 04:20 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
Jeezus Jim, That's horrible! Glad to hear you're ok though!
Old Sep 4, 2006 | 04:25 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Sorry to hear about that. Glad no one was hurt.
Old Sep 4, 2006 | 04:30 PM
suicide king's Avatar
suicide king
Wow! That sucks..... Glad you're ok.
How fast were you going?
Old Sep 4, 2006 | 04:37 PM
Dave1998's Avatar
Dave1998
I know the feeling. I hit a wheel/tire going down interstate in dark in my Grand Prix. Blew out front tire doing 60, bent rim, ruined front wheel bearing, went under car and bent both rear struts so I rear tire was on a steep angle. Car was in shop over 2 weeks. This stuff is hard to see in dark.
Good luck with repair !
Old Sep 4, 2006 | 04:41 PM
csexton's Avatar
csexton
Glad your ok Good luck with the repair!
Chuck
Old Sep 4, 2006 | 04:50 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Wow, I'd say it is time for a C6 after that string of bad luck. Glad you both are doing fine, that is indeed a scary situation to find yourself in!
Old Sep 4, 2006 | 05:23 PM
jrose7004's Avatar
jrose7004
Glad to hear that you weren't hurt but stay away from Vegas!
Old Sep 4, 2006 | 06:26 PM
vetracn98's Avatar
vetracn98
St. Jude Donor '08
I'm really sorry to hear that........but........if you get the C6 then it seems to be for the better to me.
Old Sep 4, 2006 | 07:32 PM
JiminFL's Avatar
JiminFL
Old Sep 4, 2006 | 08:45 PM
troy144's Avatar
troy144
Sorry to hear about all your bad luck
To Holy #$%!! - Not Again!!!
Old Sep 4, 2006 | 09:10 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I'll add to the list of condolences for the car and relief that you and your lady are all right. I hate it when stuff like this happens. The low ground clearance on these cars is a double edged sword. Good luck with the insurance and repairs.
Old Sep 4, 2006 | 09:14 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Wow, that sucks, here is a beer for you
Old Sep 4, 2006 | 10:06 PM
hardtop's Avatar
hardtop
Highways seem to be more littered with crap then ever before.
I hit some small stuff and didn't do much damage, but I know it's only a matter of time.
Good job keeping it on the road.
