digital climate control
Old Sep 5, 2006 | 11:18 AM
2000 vette's Avatar
2000 vette
1st Gear
Default digital climate control
Digital climate control does not work properly. Need to remove it from my 2000 vette to have it rebuilt. Need help in how to do this.
Old Sep 5, 2006 | 11:31 AM
diyguy's Avatar
diyguy
Run diagnostics (codes for HVAC) first.
Lots of links on procedure.
Old Sep 5, 2006 | 12:01 PM
brookman's Avatar
brookman
Lift up arm rest -
remove plastic covers in the rear of console
remove both nuts
pop out active handling button part by prying up from rear
remove both nuts under it
remove ashtray
remove screw behind ashtray (torx)
remove screw above lighter
carefully pop off the vent cover beside the ignition key(the tabs are on the sides)
remove torx screw behind that cover.
remove the shifter ****
remove the shifter boot
remove the console - slide back while slightly lifting the rear - then you have to manuever it out of the way.
the A/C controller is held on with 2 or 4 torx screws.
I don't think I missed anything other than undoing connectors which you will see as you remove the various components.
Old Sep 5, 2006 | 01:08 PM
wit2pz's Avatar
wit2pz
Hey, 2000Vette, does the unit simply not work, or is the display dim? If it's a dim display, there's a simple trick to fix it, as long as you have familiarity with soldering.
I'm not sure of the thread, but I'm sure somebody will post the link to it... meanwhile, try a search on HVAC Display. You might have some luck there.
Good luck!
Old Sep 5, 2006 | 01:11 PM
valet_devil's Avatar
valet_devil
You don't have to remove the ****. Unfasten the clips at the base of the shifter boot and you can pull the console up over the shifter assembly.
Old Sep 5, 2006 | 01:13 PM
rws.1's Avatar
rws.1
this forum member web site has the removal instructions....
http://www.spdkilz.com/techtipledhvac.html
To digital climate control
