[Z06] Dyno Numbers
Old Sep 5, 2006 | 01:48 PM
ActionZ06's Avatar
ActionZ06
Default Dyno Numbers
Just had my stock 03 Z06 dynoed and got 413 to the crank and 350 to the wheels. Are those good baseline numbers?
Old Sep 5, 2006 | 02:28 PM
Z06Fix's Avatar
Z06Fix
right on par. Let the modding begin!!
Old Sep 5, 2006 | 03:15 PM
ActionZ06's Avatar
ActionZ06
Yeah we just got the computer back from Flordia and it makes a world of a difference. More mods to come!
Old Sep 6, 2006 | 01:13 PM
DEEPWEE's Avatar
DEEPWEE
just wondering where you sent your ecm to? i just bought a 02 z and want to do the same
Old Sep 6, 2006 | 06:13 PM
Steve Theodore's Avatar
Steve Theodore
Sounds like a healthy 03Z to me!
Old Sep 6, 2006 | 06:33 PM
Richie Carbone's Avatar
Richie Carbone
How did you get Crank HP numbers? I doubt you had the motor pulled and ran on an engine dyno.
Your car is right on par for a stock ZO6 w/ 350RWHP.
Just wait until you install headers and gears...
Old Sep 6, 2006 | 07:14 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
That sounds on the high side of average, but right there.
Old Sep 6, 2006 | 11:43 PM
ActionZ06's Avatar
ActionZ06
On the Dyno sheet i think it was estimated horsepower to the flywheel or something i will have to look at it again or post it on the forum.
Old Sep 7, 2006 | 10:14 AM
Ryan L's Avatar
Ryan L
High side? There are a ton that pulled in the 360rwhp range.
Old Sep 7, 2006 | 10:19 AM
Ryan L's Avatar
Ryan L
There is an easier way to do this. Most RWD cars with combustion engines have the same range of drive line losses. Generally, an automatic has a 20-22% driveline loss, while manuals have a 15%. Somone people have quoted only a 12% loss for a C5, which may seem a bit to conservative. But anyway, using his 15% loss, 350rwhp is equal to about 412 hp at the crank. Using a 12% loss is right near 400hp at the crank. But yeah, the 100% accurate way is to take the engine out completely and run it on an engine dyno.
Old Sep 7, 2006 | 10:59 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
It’s hard to judge dyno numbers done by different cars, on different days, on different dynos, and with different correction values. Without seeing a chart we are flying totally blind. Peak numbers are only part of the story. Some dyno runs have spikes that exaggerate the maximum output value. All in all I would say that 350 RWHP sounds like it is in the ballpark, maybe even a little low. The flywheel quote is meaningless unless you pulled the motor and put it on a dyno.
Old Sep 7, 2006 | 06:05 PM
ActionZ06's Avatar
ActionZ06
I know there is an engine dyno, but i just assumed that was an estimated number, but i guess not i will have to find out from the guy who did the dyno run and see what he has to say.
Old Sep 7, 2006 | 09:54 PM
zo6vetteman2003's Avatar
zo6vetteman2003
A guess at the crank without doubt. Was there tuning done, or just a dyno pull? For all we know, there could be alittle left on the table depending on where the A/F ratio was. ActionZO6, you should get a copy of the dyno sheet from the guy and post it here. It's all speculation at this point, so we can't tell you anything accurate.
To Dyno Numbers
