[Z06] New Tires
Old Sep 5, 2006 | 03:36 PM
Z06Ace's Avatar
Z06Ace
4th Gear
Default New Tires
I am in the market for some new tires for my 2002 Z06. I am not sure what kind to get... any suggestions?
Old Sep 5, 2006 | 03:37 PM
pb24dagrk's Avatar
pb24dagrk
i got PS2's and love them
pricey though
can't go wrong with OEM either
Old Sep 5, 2006 | 04:10 PM
Retired GM Engr's Avatar
Retired GM Engr
pricey though
with both statements.
Although my PS2's weren't any more expensive than F1's for the "total package".
Search for "tire". Tons of info. Maybe in FAQ's too ?
Very happy with my PS2's. Details in previous threads.
P.S. ( no pun intended )
You will find a lot of people happy with much cheaper Firestone Wide Ovals, or Kumho's.
You could be very happy with these for less $'s. I'd go with the Kumho's if $'s count.
I have a "hard-on" against Firestone and their now parent company Bridgestone.
But, it's based on their truck tires that were OEM on my GMC Z71 that "blew apart at 50 mph".
And the lack of corporate responsibility. OK, it happened for their SUV tires also. And it's killed
a bunch of stupid folks who were bad drivers, and didn't wear their seat belts.
So, I have no experience with the Corvette "Wide Oval" tires.
But the fact they totally disavow responsibility for the "sh_t they produced" is "not really a plus" with me.
Old Sep 5, 2006 | 06:13 PM
Z06Ace's Avatar
Z06Ace
4th Gear
Thanks for the advice guys.
Old Sep 5, 2006 | 06:19 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I like the stock Supercars, if you use your car in the rain there are probably some better alternatives since the big tread blocks and narrow channels seem to hinder the performance of the stock tires in the rain.
If I didnt run the stock rubber I would most likely go with the Michelins, have had overall good experience in the past with them and they seem to have a pretty stellar reputation across the board
Old Sep 5, 2006 | 10:15 PM
Silver Z06 Driver's Avatar
Silver Z06 Driver
Firestone was very irresponsible with those crappy truck tires... I wouldn't use their recycled rubber to manufacture condoms!!! HOWEVER I got stuck out of town and was forced to buy 2 Wideovals for the front of my Z06..... let me tell you, ---they are 10x better than the stock F1's. Cheaper, Smoother & Quieter with almost double the treadlife, and grip is 10x better in the rain!! At 1st I didn't want them, but had to take them cause that was all the dealer could get me. I love them!!!!
Old Sep 5, 2006 | 10:23 PM
VetteFish's Avatar
VetteFish
i couldnt justify spending 1400 for OEM goodyears, so i got Kumho Runflats for 950 installed. Stick great, quiet, soft compound and mean tread pattern. I'd recommend them
Old Sep 6, 2006 | 02:18 AM
striper's Avatar
striper
I also have PS2's on my Z and they are better than the stock F1's in every possible way you can think of. Even at their price I'll buy them again.
As far as Firestones are concerned, I had their runflats on a previous C5 and they were much better than the Goodyear runflats. The whole SUV fiasco was actually Ford's fault putting the blame on Firestone. They were recommending Explorers run tire pressures too low to compensate for their crappy ride, which was causing them to overheat and explode. Car and Driver did tests simulating this occurence and found that the reason the vehicles were having accidents was driver error. They kept exploding tires on Explorers and the vehicles would stop straight every time. I had the opportunity to personally witness this phenomenom. I was driving on the highway a few years ago when suddenly I heard an explosion. I looked ahead and saw a tire on an Explorer exploding fortunately far enough ahead of me that my car didn't get hit by pieces of tire. I slowed down expecting to see this SUV flipping over in front of me. Instead the vehicle just slowed down and the driver just pulled off to the shoulder, with just the bead of the tire still surrouding the rim.
Old Sep 6, 2006 | 03:32 AM
MarkT 2002's Avatar
MarkT 2002
I went through three sets of the OEM Goodyears before I changed to the Nitto Extreme R II's. I don't run my car in the rain (if I can avoid it) but the few times I've been on wet streets with the OEM GYs they would get loose real easy. I haven't had my Nitto's on wet pavement so I can't compare the two tires under wet conditions.
But, I will say, on dry pavement there is no comparison - the Nitto's hook and handle waaay better than the GY's (they even ride better and are a little quieter). The Nitto's cost less initially than the GY's but their treadlife has a lower tread rating so I figure over time they will end up costing about the same.
I will never go back to the GY's, I'm hooked on the Nitto's.
Old Sep 6, 2006 | 01:15 PM
Retired GM Engr
Originally Posted by striper
. . . The whole SUV fiasco was actually Ford's fault putting the blame on Firestone. They were recommending Explorers run tire pressures too low to compensate for their crappy ride, which was causing them to overheat and explode. Car and Driver did tests simulating this occurence and found that the reason the vehicles were having accidents was driver error. They kept exploding tires on Explorers and the vehicles would stop straight every time. . .
I don't dispute "the above". I agree with it. I did mention "stupid drivers killing themselves".
And, I am not a BIG FAN of Ford, and how they have dealt with safety issues over the years.
I'm not talking "Pintos", but I'll keep my inside knowledge to myself.
BUT, in my truck tire failure, a blowout with foot-long rips and tears through the radial sidewall and around the circumference seems a bit extreme. With 40 psi in the rear tire, no load in the pickup, and 50 mph on a straight and level asphalt road. Luckily, my wife is a pretty good driver, and didn't hit the brakes. She just kept it straight until slowed enough to pull onto the gravel shoulder. I've still got the tire. And pictures.
I used those tires to tow my travel trailer all over the western mountains.
I know, Wide Ovals are a totally different deal.
But, I wouldn't buy a geniune Rolex from a guy who sold me a copy last year.
Integrity counts with me.
Old Sep 6, 2006 | 01:26 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Z06ace,
when you make such an inquiry, you need to advise as to how you primarily use the car - daily driver (including rain), autox, HPDEs, annual mileage, etc. Some tires are more biased to particular uses than others.
Old Sep 6, 2006 | 11:30 PM
skeet's Avatar
skeet
First thing I would look for if I were to buy anything other than Goodyear SC's (which is my first choice) would be tread width. The last tire I would buy would be the Firestone which has one of the narrowest threads per given size. This is a Z06 and junk tires have no place on it.
Old Sep 6, 2006 | 11:50 PM
vms4evr's Avatar
vms4evr
Originally Posted by wamara
Z06ace,
Yes exactly! Otherwise we could be recommending some nice offroad tires for that Z
Old Sep 6, 2006 | 11:55 PM
vms4evr's Avatar
vms4evr
You're comparing an DOT R-compound track tire to a high performance street tire. The R2 should outrun the SC, PS2, MX and any other street tire in the dry. Not a fair comparisson.
But I agree with you on the grip. I use the R2 for track and they grip great! The SC is a damned good street tire for track use also.
Just an FYI for you. Once those R2s get to half tread watch it in the rain. If you think SCs are fun in the rain these will make it just as entertaining. They are not a rain tire.
Old Sep 7, 2006 | 06:15 AM
Silver Z06 Driver
So thats why I can spin'em all the way through 1st & 2nd...Nothing quite like pumping the gas and smokin the tires through 2nd gear
Old Sep 7, 2006 | 08:51 AM
C5Longhorn's Avatar
C5Longhorn
I'm on my second set of SC's. If I ever where them out around the same time, I will try the PS2's. I'm looking for a tire that is a little quieter. I'm very happy with the performance from the SC's though.
Old Sep 7, 2006 | 09:00 AM
Hoichi's Avatar
Hoichi
I switched to PS2's and they are much smoother and quieter than the SC's. Also, they are very forgiving in the wet (my Z is my daily driver). They aren't as sticky in the dry as the SC's.
I have had them for about 4,000 miles and no noticeable wear so far.
To New Tires
Old Sep 7, 2006 | 10:04 AM
Z06Ace's Avatar
Z06Ace
4th Gear
Z06ace,
It is a daily driver and it does see the rain, although not very often. I have only had it for a little over a year but have put around 10,000 miles on it.
Old Sep 7, 2006 | 11:11 AM
MikeP's Avatar
MikeP
I went Kumho's all around from Tire Rack. I just have some road noice from the aggreasive tread pattern that I hear. But they sure hook up when you get them hot.
Mike
Old Sep 7, 2006 | 11:12 AM
MYCoupe's Avatar
MYCoupe
I would recommend the GY GS-D3's. Excellent wet or dry tires. Although they don't make a 265/40/17 you can safely use a 275/40/17 in the front. I know a lot of other Z06 owners do w/o any issues. A set from www.tirerack.com should be well under $1k.
