[Z06] New Tires
Old Sep 7, 2006 | 12:39 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Originally Posted by Z06Ace
It is a daily driver and it does see the rain, although not very often. I have only had it for a little over a year but have put around 10,000 miles on it.
Then I'd consider the GY GS-D3s, Kumho MX, Toyo T1-R, Firestone Wide Oval, to name a few.... Good luck with your decision.
Old Sep 7, 2006 | 02:53 PM
z06inVB's Avatar
z06inVB
I keep hearing that the Wide Oval is narrower than most tires for the Z 06 yet I check the specs published on Tire Rack and it seems they are within .1" of the F1 GY. They also seem to have a very high ranking from drivers as well. Am I missing something?
Old Sep 7, 2006 | 08:36 PM
GARY2004Z06's Avatar
GARY2004Z06
Originally Posted by MarkT 2002
I went through three sets of the OEM Goodyears before I changed to the Nitto Extreme R II's. I don't run my car in the rain (if I can avoid it) but the few times I've been on wet streets with the OEM GYs they would get loose real easy. I haven't had my Nitto's on wet pavement so I can't compare the two tires under wet conditions.
But, I will say, on dry pavement there is no comparison - the Nitto's hook and handle waaay better than the GY's (they even ride better and are a little quieter). The Nitto's cost less initially than the GY's but their treadlife has a lower tread rating so I figure over time they will end up costing about the same.
I will never go back to the GY's, I'm hooked on the Nitto's.
Since the RIIs are slightly larger than OEM SCs, does the speedometer and odometer need to be recalibrated ? Do the RIIs pick up more road debris as a daily driver and cause more paint chips or abrasions ? I understand that the RIIs are superior to the SCs on a road course. Does anyone know if they outperform a well heated up SC on the dragstrip.
Old Sep 7, 2006 | 10:30 PM
RLS107's Avatar
RLS107
Originally Posted by Hoichi
I switched to PS2's and they are much smoother and quieter than the SC's.
I just made the switch in July from the GY.
Old Sep 7, 2006 | 10:55 PM
MarkT 2002's Avatar
MarkT 2002
I did not recalibrate, the difference is about 1% so at 100mph you're actually doing 101mph. That's within the error rating of the Speedo to begin with.
They do kick up a little more road debris but so far no chips or abrasions. I haven't taken my car to the strip yet, but I can tell you from a standing start on the street the Nitto's hook much better than the SCs. I use to be able to break the SCs loose almost at will. The Nitto's love powershifts, in fact if you don't power shift the Nitto's have a tendency to cause your engine to bog.
Old Sep 7, 2006 | 10:56 PM
slong's Avatar
slong
Just curious, anyone check speed ratings on the wide ovals, not that a daily driver is going to max out daily or anything like that. Seemed to remember they are not quite up to par with the Z06 capabilities.
Old Sep 7, 2006 | 11:19 PM
wamara's Avatar
wamara
They are "W" rated (tested to 168 mph). Are you planning on going faster?
Old Sep 7, 2006 | 11:45 PM
slong's Avatar
slong
Only in your dreams. I would only do something like that on the track and it would be with the reputation of a much better tire manufacturer. Just putting it out there incase it could be an issue.
Old Sep 8, 2006 | 12:07 AM
vms4evr's Avatar
vms4evr
They are just a bit narrower in tread width. When you look at both the WO and SC mounted on rims there is more of an optical illusion that the WO appear a lot narrower than they really are. The SC is a very square looking tire. Flat sidewall almost. The WO is very rounded and has the rim protector which makes it appear to bulge out more. I have the WO for the street and have no complaints. Hard to beat that price. I use the R2 or used SC on track. I had the WO on track in the rain and they weren't bad. Had them on a dry track when they were new and they howled like crazy. They are not as stiff a sidewall as the SC or as sticky on a dry track. But for commuting purposes I'll take the WO and the money savings any day.
