Tire Wear Normal?
Old Sep 13, 2006 | 10:17 AM
Twin Screws's Avatar
Twin Screws
Default Tire Wear Normal?
Looking to buy a 2001 Z06...rear tires essentially bald at 18,000 miles...is this normal wear and tear as the seller claims or has he been beating the car?
Old Sep 13, 2006 | 10:32 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I got 43,000 miles out of my rears....and still had 2/32 left, tread was completely even all away across the footprint
Old Sep 13, 2006 | 10:34 AM
VERTC5's Avatar
VERTC5
My 2001 has original tires w/26K and still look new.
Old Sep 13, 2006 | 10:37 AM
TEXHAWK0's Avatar
TEXHAWK0
If I had tires that were over 5 years old, I would start to be concerned about deterioration from age and failure, regardless of remaining tread.
Old Sep 13, 2006 | 10:39 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'm approaching 12K with my OE run flats. I'm almost at the tread bars on all the tires...NO burnouts, NO track days, mostly 65 mph cruising back and forth to work, with an occasional curved X-way off ramp taken briskly. Been running 30 PSI, cold, wear is absolutely even.
Old Sep 13, 2006 | 11:26 AM
HummelS's Avatar
HummelS
My wife had an '01 Z06, and she got about 20K on the first set of tires. The car was her daily driver commuter car, and not beat on at all (60 y.o. grandmother of eight).
The Z06 F1 SC tires start life with 3/32 less tread than the runflats, btw - they are basically a "shaved" tire for optimized track performance.
Old Sep 13, 2006 | 11:33 AM
I got right at 15K miles on my set of original runflats. That is with no burnouts, hard driving and with proper air pressure. Seems like tire wear can vary greatly on these cars.
Old Sep 13, 2006 | 12:43 PM
Wavegoodbye's Avatar
Wavegoodbye
I have a stock, C5, non Z06. 16K miles, no track, no burn outs, drive normally. Wear is even across the board, but I have maybe 5/32 of tread left. Air pressure has always been set to stay at or just below 28-29 pounds hot.
Old Sep 13, 2006 | 12:49 PM
waupachino's Avatar
waupachino
I have a 00 Vert, I got 21,000 miles out of the runflats in the rear and that was it. They were starting to look hard and dry. Seemed to be in good shape until I got the 3.42 rear diff installed. The bad thing is I really didn't do any burnouts. Seriously.
Old Sep 13, 2006 | 02:36 PM
VERTC5's Avatar
VERTC5
On what experience do you base this? I have had tires last longer than this with no serious degradation.
Old Sep 13, 2006 | 03:23 PM
TEXHAWK0's Avatar
TEXHAWK0
Tire manufacturers will tell you they only design the carcas to last 3 to 4 years, but how long they last can vary depending on exposure to UV light and other factors.
I had some tires that I took off my car once, that sat in the garage for a year. A friend of mine mounted them, and the first week he had two blow outs when he crossed a RR track or other irregular surface. The tires looked fine with plenty of tread and no visable cracks.
Then you have the "Fastest Indian" that hid cracks in his motorcycle tires at Bonneville with black shoe polish and went 200 MPH.
Do you feel lucky?
Old Sep 13, 2006 | 04:14 PM
jrose7004's Avatar
jrose7004
I'll bet the previous owner did a lot of burn outs!
To Tire Wear Normal?
