Looks good man, thanks. A little tip on photobucket though, use the "IMG" tags underneath each of your pics. Copy and paste that directly into your post and the picture will show right in the post instead of a link. Try it...
Curious to hear opinions on this and maybe pictures too. I am going to order an MTI Six shooter and want a new **** to go with it. considering the Delrin ****. I think that would be a super short setup b/c that ***** is an inch lower than the stock **** + the shifter is an inch lower too.
When you shift, do you grab the top or the side of the shifter? I'm asking because if you're used to shifting from the top, there are better options than the Delrin shift ****. The Momo **** pictured above would be a good choice for "top shifters". The Delrin shift **** is great if you shift it from the side.
Also, keep in mind that the Delrin **** sits higher than other ***** and is best used in combination with a shifter with a very short throw and short shaft like a Hurst. I don't know how the MTI compares to the Hurst in this respect.
Do not attempt to use a Delrin **** with the stock shifter. You'll think that you're driving a semi.
If you're thinking about going with the Delrin ****, just do it. They are THREADED and screw down onto the shifter shaft. This is FAR better than these other ***** that require keeping a set-screw tight to keep them tight to the shaft.
Stock I have tried a few, and I keep going back to stock, well stock style. I am running a WCC red and black OEM style **** with 2 tones boot on a Hurst. I love it!!!!
Did try a polished marble old school style hurst pool ball for a month or soo and swapped it back. Looked OK but out of place. The feal was finda numb IMO o wait, my hand was numb after all the vibration lol!!!
Dave
Me too. Although mine came apart at the seam, so I pryed it totally apart and used JB Weld on it and it has held up for 4 years. It is a nice solid shiftknob.
It is nice to become a supporting member no doubt, but as far as general management of all your pics & vids there is a huge difference with other sites like photobucket.com. I support the forum by buying products from the sponsors
I put in a C6 **** from GS Creations over the weekend and swear its a good bit higher trhan stock was. Not sure if it will stay. Maybe I need to brake down and buy the shifter assembly from the C6 to complete the package.
