Tire Pressure Sensor Question
Old Sep 26, 2006 | 12:32 PM
rwsr50's Avatar
rwsr50
Default Tire Pressure Sensor Question
Discovered low pressure (19psi) in my RR tire when I checked it with a gauge. Turned the key to on, and sure enuff, it showed up on the DIC as low pressure. Repaired the tire, blew it up, turned the key on again (without starting car), and the DIC showed 30 psi. Didn't have to hit reset or anything.
So, I figured I'd be pretty clever, and adjust the pressure in the other tires using the DIC while inflating them. Some were showing 29psi and I wanted to get them to 30. No matter how much air I put in the tires, the DIC wouldn't budge off 29. Made me wonder if my sensors were bad or something. So, I just set the pressures with the gauge.
When I drove it this morning, the DIC showed 30 for all 4 tires, and increased as they warmed up. Go figure??? Does the engine have to be running maybe?
Old Sep 26, 2006 | 01:14 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
You usually have to drive a little before you get an accurate reading after filling the tire. It generally (but sometimes will) will NOT adjust the reading on the DIC after you fill it until you drive. You did the best thing by using a hand sensor to check it.
Old Sep 26, 2006 | 04:42 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
The tires have to be rolling.
Old Sep 26, 2006 | 04:50 PM
jan-db's Avatar
jan-db
How come the DIC shows a DECREASE in pressure right now but you have to go around the block to show an INCREASE in pressure. Just asking.
Old Sep 26, 2006 | 05:34 PM
AtiLLa's Avatar
AtiLLa
My '01 owners manual says that you check the pressure with the DIC after reaching a speed of 15 MPH or more. I don't think it was intended to be used as a pressure gage for inflating the tires. You should use a good quality hand gage to set the tire pressure. The sensors in the tires are just used for you to "monitor" the pressure as you drive and to alert you when you have a problem.
atilla...
Old Sep 26, 2006 | 08:43 PM
xilr8n's Avatar
xilr8n
I read on them that they only send a signal every 20 min or so when stopped and all the time when doing >20 (battery saving mode)
Old Sep 26, 2006 | 08:50 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I don't know what year your car is, but on the late model (2001+) sensors, they update about once a minute when moving, and once an hour when not moving.
If you filled a tire up and got an immediate update without driving, you got lucky, it happens.
But it does not mean your other sensors are bad...it's a common misconception that the sensor readings are shown in real time...they are not. You need to drive and let them update.
Old Sep 27, 2006 | 12:41 AM
The car has to be moving before the sensors will give an accurate reading. Use a good tire guage and you should be OK.
To Tire Pressure Sensor Question
