[Z06] Need new Rotors
Old Sep 29, 2006 | 10:50 AM
Road machine's Avatar
Road machine
to AU :
The slotted rotors do still help these days with pad fade which is caused by the outgassing of the binder material of todays pads. Yes they do wear the pads a little faster, but pads are cheap, new underwear needed after pressing the brake pedal hard at the end of a long straight and nothing happening, Priceless. I totaly agree with you about drilled rotors and I would never consider them. As far as the 8 lbs lighter, I believe that the 8 lbs is an "upto" spec which we all know can mean anywhere from heavier to 8 lbs lighter. My buddy did actualy weigh them against stock rotors and told me they were 5 lbs lighter than stock fronts. One other thing to consider when buying rotors is balance. For my Dodge Magnum, I bought cheap rotors, made in china. After I changed the rotors and the pads, I felt a vibration at high speed. I thought it was that the rotors had high spots but the vibration didn't increase under breaking. I took them to my shop and miked them and they seemed fine. I threw them on a lathe to indicate them and could see just by looking that the rotor was way out in the radial direction. Obviuosly the core had shifted in the casting process. I returned them ( which wasn't easy since I couldn't bring my lathe to show the run out) and got a set of Raybestos rotors. A lot more expensive than the chinese junk, but I don't like junk at any price.
Old Sep 29, 2006 | 12:48 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Originally Posted by The Machine
pads are cheap
Pads are cheap?? have you quoted a set of DTC-70s yet? They are not cheap especially compared to $17 rotors
As far as gas release - I thought that went away with asbestos brakes. The new Ferro-Carbon do not see any advantage with gas release. I could be wrong with this assumption though. I just thought I read that somewhere. Maybe someone could confirm or deny before I spread rumors
Of course we all know cooling is the most important. Adding Ducts to the front brakes makes a huge difference at keeping the rotors cool.
