Glue issue :-( ????????????????????
Old Sep 27, 2006 | 08:55 AM
MedChoice Tony's Avatar
MedChoice Tony
Default Glue issue :-( ????????????????????
I had sprayed some spray glue in my garage and some got on the paint of my car and it's "black" as well as some on the windshield and side window. Now, I wanted to know what can I do about this - besides never doing it again! What products should I use on the Paint and Window.
Thanks,
Tony P.
Old Sep 27, 2006 | 09:17 AM
Luv2Run's Avatar
Luv2Run
St. Jude Donor '13
As a start, I would try WD40 and/or GOJO (the hand wash gel). For the glass try using a razor blade first.
Good luck...it will come off, just do not use anything abrasive on the paint. I'm sure you realize that.
Don
Old Sep 27, 2006 | 09:26 AM
MedChoice Tony
Thanks for the info - what does WD40 do to the paint? Also, can I use Goo Gone for the windows to remove the paint. Can I use a scratch remover and polish the car to remove the paint from the car?
Thanks,
Tony P
Old Sep 27, 2006 | 09:46 AM
2000BSME's Avatar
2000BSME
wd40 is a good suggestion, if that doesn't work, some Goo Gone will work.
Goo be gone, will take off wax, I'm pretty sure.
I don't think wd40 will hurt the paint in the least.
Old Sep 27, 2006 | 10:14 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Denatured alcohol (Lowes, paint store etc..) is your friend. Has never harmed plastic, paint, etc. that I've used it on .
Old Sep 27, 2006 | 10:24 AM
MedChoice Tony
Hi, sorry but how does WD40 take off glue?
Thanks,
Tony P
Old Sep 27, 2006 | 12:38 PM
2000BSME's Avatar
2000BSME
Thanks,
Tony P
Water Displacement Formula #40 has a variety of uses other than the original design criteria of displacing water.
Old Sep 27, 2006 | 12:52 PM
cuspid's Avatar
cuspid
Read the package on wd 40, excellent for removing stickers on the paint. Says it on the container, I beleive it is kerosene. Hate those price stickers they put on things and bumper stickers.
Old Sep 27, 2006 | 01:08 PM
Patches's Avatar
Patches
Get yourself a clay bar from the parts store. That should safely take it off.
Regardless, you'll need to reapply wax afterwards.
Old Sep 27, 2006 | 01:53 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Works great on glass too.
Old Sep 27, 2006 | 02:54 PM
Cole's Avatar
Cole
Another claybar supporter. Easy and fast and no chemicals. Goo Gone is a great product and pretty safe, but claybar should do it.
steve8's Avatar
steve8
I would also start with wd-40. It's safe, but definitely need wax when through.
Old Sep 27, 2006 | 03:31 PM
Dave68's Avatar
Dave68
Claybars + detail spray to keep it lubricated.
Old Sep 27, 2006 | 03:32 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
3M sells a can of glue removal.
http://www.madvet.com/shop?frame=2.58.166
From Mid-America. Used it when I installed koolmat to clean up over spray.
To Glue issue :-( ????????????????????
