Valve stem question?
Sep 27, 2006 | 10:11 AM
I have a '98 C5. Does anyone know if a regular valve stem (innards) can be used to replace a possible defective one on the Corvette. I have had a very slow air leak with the old and now new tire. I loose about 5 lbs of air in about two months, and the alarm kicks in (low air, LR). Tire dealer wants to replace the entire valve unit for $70.00. I'm not sure this is necessary.
Chuck
Sep 27, 2006 | 08:41 PM
Sep 27, 2006 | 09:29 PM
2017 C7 of the Year Finalist
St. Jude Contributor
The pressure sensor IS the valve stem. The entire unit must be replaced, it's all in one.
You could possibly fix a leak around the valve with an "O" ring
Sep 30, 2006 | 08:57 PM
Thank's, I appreciate your response. I didn't know that. I'll try the O ring fix first.
Sep 30, 2006 | 09:36 PM
The mechanicals in the valve stem ARE the same as any valve stem. If you are refering to the scchever (sp) valve inards.
Oct 1, 2006 | 10:40 AM
Quote:
Originally Posted by Oldvetter
The mechanicals in the valve stem ARE the same as any valve stem. If you are referring to the Shrader valve innards.
...fixed it for you...
GUSTO
Oct 1, 2006 | 03:54 PM
Quote:
GUSTO
Thanks, I am an engineer and can't spell worth **** !
Oct 1, 2006 | 06:22 PM
GUSTO
Well, not quite. It's Schrader.
Oct 2, 2006 | 09:00 AM
Quote:
Touché...
GUSTO
