Start button ignition...possible??
Old Oct 1, 2006 | 01:45 AM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Originally Posted by Antvette
I say mad the ignition to recognize your fingerprint. That is the best anti-theft there is unless you loose your finger...then your goosed.
Kinda like that Cadillac Cien in the movie "The Island"
Old Oct 1, 2006 | 02:25 PM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
Originally Posted by AC54ME
Old Oct 7, 2006 | 12:59 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by sceia
Is it a momentary switch, or something more fancy? I'm gonna be installing a python alarm system, and it has a momentary switch that I was thinking of replacing...
Yea, just thought of the next mod, after headers and sway bars.....
Ive got the headers and sways waiting for me when I get home from offshore, and think I'm gonna do the alarm at the same time now. Gonna get the ir sensor for the vert and voice warning module....oh yea baby....
Scott.
It's nothing more than a momentary switch and a relay. I added a safety switch to arm it, but otherwise, it's pretty straightforward.
EG
Old Oct 7, 2006 | 01:27 PM
zo6vetteman2003's Avatar
zo6vetteman2003
You have to install a resistor to match your key's pellet resistor's resistence first, and wire in the switch, or it will not work. A 10K ohm pot works very well. The two wires where the resistor is installed across are white with a black stripe and purple with a white stripe. These go to a plug found in the rear of the existing ignition cylinder. The wires go directly to the BCM located in the vehicle's passenger foot well. You will be bypassing your VATS in short.
