Body Panel Question
Old Sep 29, 2006 | 03:16 PM
Boob's Avatar
Boob
Default Body Panel Question
What is the term for the baseboard that runs under the door. The bottom piece that curves under the car and bolts at fender etc. I have a HUGE scratch in it and no idea how it got there... don't know that it can be repaired and was thinking of buying a new piece from the dealer.
Old Sep 29, 2006 | 03:32 PM
NEVERL8C5's Avatar
NEVERL8C5
It sounds like the rocker panel. This is not very expensive to purchase but requires 6 hrs book labor to install and bond. Both sides including paint was $2037.00. I would try and repair the scratch. A good body shop can do wonders.If anyone has ever had the forward attach area broken off Ecklers sells this repair kit for $40 dollars and it works perfect.Good luck.
Old Sep 29, 2006 | 03:39 PM
Taxin's Avatar
Taxin
St. Jude Donor '06
I believe you are speaking of the rocker panel and it is not a simple diy job
Old Sep 29, 2006 | 05:14 PM
Boob's Avatar
Boob
Will do. After settling down a little (I was pretty upset)I'm thinking I'll sand/bondo it then take it in and have the whole car repainted this winter. After 7 years she's due for some fresh paint.
I cracked the part where it mates up on the other side and have to replace the fender as I chipped a piece the size of a quarter out....just really horrible luck lately.
Old Sep 29, 2006 | 07:11 PM
DeeGee's Avatar
DeeGee
You might want to consider the frame savers and rocker rails to solve the problem for the future. Forum Vendor A&A Corvette sells them. Run down to the bottom of the link.
https://www.aandacorvette.com/cart/s...sp?MainCatID=5
Depending on where the damage is it may even cover it up.
To Body Panel Question
