Problem with vent control.
Old Sep 29, 2006 | 05:28 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default Problem with vent control.
I have a 98 with the manual AC controls. The temp **** works, the fan speed works, but the vent position switch doesn't it blows thru all the opening no matter where I turn it.
Old Sep 30, 2006 | 12:14 AM
Omega Man's Avatar
Omega Man
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
you need to check the vac line on the back of the ****. It sounds like you have a leak.
Old Oct 1, 2006 | 08:20 PM
acerider's Avatar
acerider
I had the same problem on my 98, but with the electronic controls. Mine was due to the little vacuum line on the back of the intake manifold being disconnected. I had to pull the manifold to get back there to reconnect it, but it's worked perfectly ever since. I don't know if the manually-controlled A/C has the same setup, but you might want to take a look. Kind of a PITA, but not particularly difficult to fix. Good luck!
Old Oct 1, 2006 | 09:57 PM
Taldir's Avatar
Taldir
I had this issue - fixed today.
Battery acid ate thru my vacuum line completly - it was located under the battery tray.
I conntected the broken ends with some 1/8 vacuum line then taped the ends up.
Easy easy fix.
Old Oct 1, 2006 | 10:39 PM
DanielW's Avatar
DanielW
Easy easy fix.
I did have a acid leak....I will check into it. Thanks.
To Problem with vent control.
