How important is the 50/50 mix? When I changed my coolant I wasn't paying attention when refilling and ended up putting too much coolant in. I probably have something like 75% coolant and 25% water. I didn't really worry about it afterwards and haven't noticed any problems, but I do need to correct it if there might be some long term negative effects.
Not sure what brand you put in, but Dex-cool recommends 50/50 mixture, max 60% if you live on the frozen tundra. Your 75% is high. I'd do the calculations on what you put in against the capacity and work up a dilution scheme. Another way would be to get a antifreeze tester, determine what level your protected down to, ie -50 degrees, and start dilution from there. I think the container provides estimated protection ranges as a reference. Not sure if and what the downside is if you leave it at the current level.
Higher coolant levels will cause higher temperatures (pure water cools best). Plus it will tend to leak easier (lower surface tension).
Also found this: "Using antifreeze without mixing it with water can damage the engine by causing high operating temperatures. Additives in the antifreeze can also gum up cooling system passages and damage water pump seals. Glycol should make up between 40 and 60 percent of the mix for best results."
[QUOTE=Oldvetter]Higher coolant levels will cause higher temperatures (pure water cools best). Plus it will tend to leak easier (lower surface tension).
I have worked on cars that were overheating because the owner poured in too strong of a coolant mix.
I agree with some of the above posts, water cools the best. Mix it according to the conditions you will be in. If you don't need protection down to -10 F you may not need as much coolant as others way north of you. There should be a table on the antifreeze container or get a tester from the local auto house. good luck
Find some way to dilute the coolant with water to bring it more in line with a 50/50 mix.
If you have a 70% coolant (30% water) mixture, and the cooling system capacity is 12.6 quarts, you just need to drain 3.6 Qts out and add back 3.6 Qts. of distilled water to get back to a 50/50 mix.
X = qts of 30% water mix to drain
12.6 x .5 (desired mix) = X (1.0) + (12.6 - X) .3
6.3 = X + 3.78 - .3X
6.3 = .7X + 3.78
X = (6.3 - 3.78) / .7 = 3.6
