Help me pick..
Old Oct 2, 2006 | 10:45 PM
C5-GIRL's Avatar
C5-GIRL
Default Help me pick..
I'm going to make one of these into a 16x20 print -
Which would you pick - I'm leaning towards number 3
Thanks!
Janelle
Old Oct 2, 2006 | 10:47 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
1 or 3 and i would crop them
Old Oct 2, 2006 | 10:48 PM
ja03c5's Avatar
ja03c5
2 or 3...I like the darker #2 with the fogs and all...
Old Oct 2, 2006 | 10:50 PM
35thAnivSS's Avatar
35thAnivSS
#3...but make sure you leave in the 'Please Drive Carefully' sign, its classic.
blackwithyellowta's Avatar
blackwithyellowta
has to be #3
Old Oct 2, 2006 | 10:53 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Make one of each
If it could only be one then I would choose #2
Old Oct 2, 2006 | 10:54 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Seeing how you asked None Take some more pics
ALLEGRO's Avatar
ALLEGRO
Number one looks very "mean."
I did the same thing a while back
Old Oct 2, 2006 | 10:56 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
#3 cropped.
Old Oct 2, 2006 | 10:59 PM
rgtkst's Avatar
rgtkst
the order i like them
if number one had the pic taken at a angle showing more of the car, as in the camera not pointing up from the ground as much i think it would make a perfect shot. the third one, if the backround was more pleasent would also be nice. or.... bad azz also
more like the post above.
Old Oct 2, 2006 | 11:01 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Wow you go through more custom lisence plates than... well i cant really think of an apropreate example
I like 1 and 3, go for both and put them up in the garrage
Old Oct 2, 2006 | 11:06 PM
pointu's Avatar
pointu
From: sometimes the lights are shining on me, other times i can barely see minnesota
i vote for 2-should have had a poll
Old Oct 2, 2006 | 11:09 PM
Vassili's Avatar
Vassili
numero 2
C5naples's Avatar
C5naples
#3, It says a lot
Old Oct 2, 2006 | 11:14 PM
Z06-JIM's Avatar
Z06-JIM
This is an awesome low angle shot of your vette... ...defiantly the one I would pick...
CHUXDRM's Avatar
CHUXDRM
I like #2, low, dark, and "stealthy".
Old Oct 2, 2006 | 11:15 PM
zonsolo's Avatar
zonsolo
I'd say #3 for its coolness factor, but is it me or is your door part way open?
Plus its blurry at the size it is, it would look horrible as a big print. You'll need to have much larger stock to make a print that looks good 16x20. The edges just aren't sharp enough in these shots with the exception of maybe #1 depending on how big your original is.
To Help me pick..
Old Oct 2, 2006 | 11:16 PM
C5-GIRL's Avatar
C5-GIRL
The lady's at the courthouse where I order the tags - " oh you again - $44 please "
Old Oct 2, 2006 | 11:17 PM
TomBoy's Avatar
TomBoy
I like #3 cropped too..
Old Oct 2, 2006 | 11:19 PM
PUREFUN's Avatar
PUREFUN
Okay, if i have to choose #3.
