How do you get at blower motor to remove mice nest
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Take belt off, and remove the 4 or 5 imperial bolts...and the blower falls right out.
as for the A/C blower, hold on i've gotta look that up.
Welcome to the forum.
Originally Posted by GM manual
# Remove the front floor kick-up panel. Refer to Kick-Up Panel Replacement - Front Floor in Interior Trim.
1 Remove the cover from the I/P electrical center.
2 Remove the BLO MOT (blower motor) MaxiFuse® #49 from the I/P electrical center.
3 Remove the I/P lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - Instrument Panel (I/P) Lower in Instrument Panel, Gauges and Console.
4 Disconnect the blower motor resistor electrical connector from the blower motor.
5 Disconnect the blower motor cooling tube from the HVAC module.
6 Remove the three blower motor retaining screws.
7 Remove the blower motor with fan from the HVAC module.
1 nstall the blower motor with fan to the HVAC module
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2 Install the blower motor retaining screws.
Tighten
Tighten the blower motor retaining screws to 1.7 N·m (15 lb in).
3 Connect the blower motor cooling tube to the HVAC module.
4 Connect the blower motor resistor electrical connector to the blower motor.
5 Install the I/P lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - Instrument Panel (I/P) Lower in Instrument Panel, Gauges and Console.
6 Install the BLO MOT (blower motor) MaxiFuse® #49 to the I/P electrical center.
7 Install the cover to the I/P electrical center.
8 Install the front floor kick-up panel. Refer to Kick-Up Panel Replacement - Front Floor in Interior Trim.
Notice
Tighten
St. Jude Donor '06
Heat/AC blower
Hope this helps this is on how to R and R the blower...perhaps there's a shortcut.
Again thank you
Bob
Received 19,441 Likes
'20-'21-'22-'23-'24
Good information - thanks Stangkiller.
https://www.corvetteforum.com/forums...wer-motor.html
I would disconnect the neg battery cable before starting ANY electrical work on my C5...just sayin.
It also will help if Ya'll will fill out your public profile info Year of Car, Auto or Manual... these can very a lot from different years.
