After you set the radio and other settings, all you should have to do is hold down the memory button a few seconds and everything should be saved to the button you selected. Unless it's losing power to the radio for some reason, it should return to the settings you selected. Are you using the key fob to unlock the door? If not, you'll have to push the memory button you preselected to get the new settings (before the car is in motion)
