ramps?
Old Oct 7, 2006 | 08:09 PM
jimbosr's Avatar
jimbosr
Default ramps?
what ramps are the best for the buck. looking at walmart ramps.. what do you all use.... thanks jim...
Old Oct 7, 2006 | 08:12 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
You are going to hear a lot about the rhino ramps which are excellent but run close to $200. I have seen some guys and gals on here make thier own out of 2X6 boards, and I have seen an adapter that will work on the metal ones that you can buy at most part houses.
Old Oct 7, 2006 | 08:14 PM
Patches's Avatar
Patches
Hmm . . . I have two sets of Rhino Ramps that were $20-$30/set depending on where I bought them.
There is a vendor here who sells a high-end version for that high price but the type I bought are available everywhere.
Old Oct 7, 2006 | 08:16 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
My mistake! I was thinking of the Race Ramps that are the expensive ones.
Old Oct 8, 2006 | 02:16 AM
NAVY08's Avatar
NAVY08
I made my own with 2x10's cost me like 30 bucks in wood and a few mails, and i designed them so my car doesnt scrape when i roll up on them, they are taller than the rhino ramps and with a less steep incline, which on the downside does make them kinda big and heavy. i dont have pictures though, but i did stencil C5 flag emblems on them
Old Oct 8, 2006 | 03:35 AM
I have a set of the Rhino Ramps that I bought at Wal-Mart. $30 for them. Work just fine.
Old Oct 8, 2006 | 03:42 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have the same ones and they do the job fine
Old Oct 8, 2006 | 05:43 AM
DeeGee's Avatar
DeeGee
The gray Rhino ramps are slightly wider and run at about $35 at Walmart
Old Oct 8, 2006 | 10:57 AM
dndrsn's Avatar
dndrsn
I think you talking about "Race Ramps" being $200. Rhino ramps are inexpensive and can be had a Wallyworld for $30 or so.
Old Oct 8, 2006 | 11:03 AM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
I just got a set of the 12000 lb Rino Ramps at Wallmart. Worked great on my Z06.
Old Oct 8, 2006 | 11:05 AM
gordonb50's Avatar
gordonb50
In my opinion, the gray ones from Wal-Mart are the best bang for the buck (approx $30 per pair). The black ones will work, but aren't as wide (approx $25 per pair).
Old Oct 8, 2006 | 11:58 AM
Vega$Vette's Avatar
Vega$Vette
Are you guys driving up on these Rhino Ramps or jacking the car and putting the ramps under the wheels?
Old Oct 9, 2006 | 01:08 PM
Vega$Vette's Avatar
Vega$Vette
ttt
Old Oct 9, 2006 | 01:29 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
That is what i got
Old Oct 9, 2006 | 02:16 PM
xwing's Avatar
xwing
I used Rhino ramps. I had no complaints, but now I use a lift, which is sooo much better.
Old Oct 9, 2006 | 04:10 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Wally World at about $25-$30. Zuti
Old Oct 9, 2006 | 07:30 PM
hotrod03's Avatar
hotrod03
Did you buy four of them?
To ramps?
Old Oct 13, 2006 | 09:05 PM
Vega$Vette's Avatar
Vega$Vette
Thought I would test the Rhino Ramps ($38 a pair at Wal-Mart) before I put the Vette on them.
Old Oct 13, 2006 | 11:29 PM
robertp's Avatar
robertp
Drive up. I lay a 2x8 ahead of the ramp. It keeps my spoiler from hitting.
Old Oct 13, 2006 | 11:35 PM
C5naples's Avatar
C5naples
I use grey Rhino ramps
