[MN6]AMSOIL ATF Installed
Old Oct 8, 2006 | 02:51 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Default [MN6]AMSOIL ATF Installed
Yesterday I drained out the RP Sychromax trans fluid and refilled with the AMSOIL ATF fluid. I wasnt expecting a difference since both are top notch synthetics. (i have Amsoil in the motor and diff. So i decided to be consistent with the fluids.)
I took the car out for some "spirited" driving. Right off the bat, shifting through the gears was alot smoother and the tranny is quieter. When driving around town, the shifter just slid into each gate like butter.
Just wanted to share my experience with everyone
Old Oct 8, 2006 | 05:39 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Cool Ike I stick to Redline stuff but would like to try Amsoil some time.
Offtopic: What clutch are you running?
Old Oct 8, 2006 | 06:10 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Im still original OEM clutch. been 2 years now on the h/c. still grips fine
Old Oct 8, 2006 | 06:39 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks for sharing the results with us.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Oct 8, 2006 | 07:15 PM
bomax's Avatar
bomax
I just did the same procedure, although surprisingly, I was only able to get about 3.3 quarts before it became full. It was on a level surface and I let it drain thorougly...hmm...
Anyway, took it for a spin and definitely notice a difference. The shifting feels looser. Still has that notchy feel though, unfortunately.
Old Oct 8, 2006 | 07:58 PM
Good to know. I need to change the fluid in mine one of these days and will consider the AMSOIL.
Old Oct 9, 2006 | 12:54 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
your fine..i just rechecked my left over bottle, its a little bit above 1/2 mark so im prob 3.4 qts too.
you should switch to hurst shifter..zero notchiness..just solid throws!
Old Oct 9, 2006 | 01:09 AM
Tino's Avatar
Tino
Next oil change I will also use the Amsoil
Old Oct 9, 2006 | 01:24 AM
CraZee ZO6's Avatar
CraZee ZO6
you should try it again when its time to see if its because of the FRESH new synthetic fluid or its really because its amsoil instead of royal purple.
Everytime I change my engine fluid with RP it feels better. Its because I got used to the oil that had 3K+ on it. Just a thought.
Old Oct 9, 2006 | 08:34 AM
vettes4fun's Avatar
vettes4fun
Amsiol is the best out there.
Old Oct 9, 2006 | 08:45 AM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
so which lube would i buy for my mn6? is it the MTG lube or ATF? thanks, dave
Old Oct 9, 2006 | 10:21 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Thats a good point, I thought of that too. However, 2 things:
1. I only put it RP in there in May right before CI-7. I guess the test would be if the smoothness holds out.
2. One thing that I noticed was that royal purple fluid for whatever reason made my trans louder when cruising on the highway. i could hear some slight whining from the gears. I figured, its prob from all the hard driving I do with this car, its expected.
guess what...no more whine!
Old Oct 9, 2006 | 10:23 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
ATF
Its GM Dexron III specification exactly what the MN6 calls for.
PS- get the hand pump too which plugs right into the bottle. So much easier to refill with that.
Old Oct 9, 2006 | 10:24 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
nice. I am using Redline products for Diff and tranny, but going to Amsoil for oil.
Old Oct 9, 2006 | 10:33 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Good move wicked, I wonder if your avg oil temps on the track will be lower.
Old Oct 9, 2006 | 10:48 AM
Wicked Weasel
I really dont think so. The oil will heat the same, but I would like to see how much the Amsoil breaks down compared to M1 or other brands.
I will probably send it out to the lab after a weekend on the track and see the differences.
Old Oct 9, 2006 | 11:17 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Old Oct 9, 2006 | 11:47 AM
C66 Racing's Avatar
C66 Racing
As Ike mentioned, GM requires a fluid meeting Dexron III specifications for the MN6. The AMSOIL ATF meets this specification and is what I have been using in my Z06 for several seasons now without any failures.
Interestingly, the AMSOIL recommendation for the T56 tranny in the Dodge Viper is the MTG so the MTG would probably work just fine in our tranny as well, but... you'd be outside the owner's manual requirements. I recommend sticking with the ATF.
To [MN6]AMSOIL ATF Installed
