Changing Turn Signal bulb?
Old Oct 9, 2006 | 11:24 AM
KnightRider02's Avatar
KnightRider02
Default Changing Turn Signal bulb?
I am a newbie, but is it hard to get at the turn signal bulb in an 02 vette? The blinker is out and I was wondering because i need to change it on the passenger side. I looked under the hood and it looks impossible, any help or how to's would be great.
Thanks,
J
Old Oct 9, 2006 | 11:31 AM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
The way I get to mine is by taking the access panel off that is in the wheel well.
slvr bulit's Avatar
slvr bulit
If you have skinny wrist's try pushing the brake vent back and to the side and try to stick your arm up in there to reach bulb. Good luck it's a mother...
Old Oct 9, 2006 | 11:59 AM
possessed's Avatar
possessed
Pop the hood and raise the headlights. There is a bolt with a rubber stopper at the front radiater area. Take it off and it will make it easier to slide your hand down there. Expect to lose a little skin but it can be done. Yes, it's a pain in the azz!!! Changed one 2 weeks ago.
Old Oct 9, 2006 | 12:34 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Old Oct 9, 2006 | 12:42 PM
DeeGee's Avatar
DeeGee
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Old Oct 9, 2006 | 01:53 PM
Zilla's Avatar
Zilla
10 minute job.
Suggests 1 and 3 only work if you have [arnolds voice]Girlie arms[/arnolds voice]
Old Oct 9, 2006 | 02:38 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
I have girlie arms, and it works great
Old Oct 9, 2006 | 03:45 PM
pjm710's Avatar
pjm710
do it right take the pannel off and put clear corners in while your in there
Old Oct 9, 2006 | 03:51 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
It's only 5 small bolts that come right off and you have plenty of room to get in there and get the plug out. Sometimes the plug can be 'weathered' in place, and going through the headlamp housing, it can be hard to get a good grip and see what you're doing. Just get a set of Rhinos at Wally World (the gray ones), drive it up, remove the panel, and change it. Ten minutes and you're done. Zuti
Old Oct 9, 2006 | 05:29 PM
RedY2K's Avatar
RedY2K
I found that using the 3rd method described in "DeeGee's" post, but with the added step of removing the bolt with the rubber stopper as suggested in "possessed's" post works for those of us with thicker arms.
Old Oct 9, 2006 | 05:56 PM
SeaBass2001's Avatar
SeaBass2001
i just had to turn my headlights on and somehow i got my arm down there it only took about 2 minutes very simple
Old Oct 9, 2006 | 09:10 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Hey, has anyone replaced the corner bulbs with an equivalant LED? They should be a one time fix... do they exist???
Old Oct 9, 2006 | 09:33 PM
rcingram's Avatar
rcingram
USAFVET
I just put in blackouts and pulling the whole light fixture was a b$tch but once I did it, no problem putting it back. Not sure of the other suggestions but I may try one of them the next time I have to get in there.
Old Oct 9, 2006 | 10:10 PM
TEXHAWK0's Avatar
TEXHAWK0
There are only 6 or 8 small screws to take out to remove the lower panel (between the air dam and the wheel well), and you will have plenty of room. I just removed the whole lens assembly through the lower panel opening, so it is no problem to get to the bulbs.
Old Oct 10, 2006 | 09:12 AM
NOLAVette's Avatar
NOLAVette
I just replaced mine on the left front by removing the hood support bolt with the rubber cap method. By far the easiest and fastest way to go. I was wondering about something though, while my arm was down in the hole-what would happen if the headlight decided to close on your arm? How powerful is that motor? Could be painful, huh?
jrose7004's Avatar
jrose7004
Old Oct 10, 2006 | 03:22 PM
KnightRider02
I was thinking about doing that
Old Oct 10, 2006 | 05:20 PM
stingray4me's Avatar
stingray4me
I put in orange bulbs by mistake. It looks cool even more orange than normal.
To Changing Turn Signal bulb?
