Correct Tire Pressure
Old Nov 9, 2006 | 12:48 AM
Try shooting for 30 psi hot on the tires. Setting them at about 28 psi cold should do the trick.
Old Nov 9, 2006 | 05:13 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
The sticker on the door is the pressure for the stock run craps. The runcraps have a very stiff side wall. I’m running the Goodyear GSD3s (non-runcraps), 32 psi cold seems to work well.
Old Nov 10, 2006 | 12:49 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...and in the summer if/when temps reach in the 90's your pressure could go up to 36-38 range and thats too much and your tires will wear in the center more
Old Nov 10, 2006 | 01:08 AM
thisMSGgood4me's Avatar
thisMSGgood4me
So? Maybe he wants the centers to wear more!
Old Nov 10, 2006 | 10:13 AM
ebubman's Avatar
ebubman
perhaps check the om? bub
Old Nov 10, 2006 | 11:35 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
yea...maybe
btw...did you forget to fill out a profile?
Old Nov 10, 2006 | 02:20 PM
thisMSGgood4me
No, I didn't forget. Is seeing a profile that important to you?
Old Nov 11, 2006 | 10:13 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Yes mam, it actually is..to me and most other members....for example,(even though you are not selling a vehicle), it is against forum rules to post a car for sale with a profile...any particular reason for hiding everything?
Old Nov 12, 2006 | 12:45 AM
thisMSGgood4me
Check my profile now Yello. I'll wait.
Now you know something about me. Happy now?
BTW I would think it would be against forum rules to post a car for sale without a profile. That would make more sense to me. What do you think?
Old Nov 12, 2006 | 02:43 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Nov 12, 2006 | 04:03 AM
Corvette1996LT1's Avatar
Corvette1996LT1
Originally Posted by Bill Vett
Look on drivers door for proper inflation. Start with 30 psi cold and keep an eye on tires. Center wearing to much air, outside not enough air. (add 2 lb.) The side wall psi is just the max for that tire. The door psi is for the weight of the vehicle.
Old Nov 12, 2006 | 01:56 PM
JC in XTC5's Avatar
JC in XTC5
Max pressure value stamped on a tire is NOWHERE NEAR the recommended pressure. It indicates the highest cold pressure the tire is designed to contain, i.e. after which it will likely fail.
30 psi is the recommended pressure for the C5.
Old Nov 12, 2006 | 07:58 PM
  #33
Yello95's Avatar
Yello95
St. Jude Donor '11
YA!..it was a typo"with/without"...whateva ...but of course you knew that ...and thanks for giving "US" a great profile...I am personally thrilled
Year & Model:
'04 Coupe
...MS...
Old Nov 12, 2006 | 08:00 PM
  #34
Ta-taaa's Avatar
Ta-taaa
Originally Posted by BuckyBoy
That's the max for hauling, etc. I would follow whats on the drivers door... seem to be happy with 28 all around.
Ditto
Old Nov 12, 2006 | 09:50 PM
  #35
thisMSGgood4me
Year & Model:
'04 Coupe
...MS...
I'm so glad you're now pleased Yello. That makes my day!
BTW check my profile again. I updated it some more JUST FOR YOU!
Old Nov 12, 2006 | 10:28 PM
  #36
Yello95's Avatar
Yello95
St. Jude Donor '11
Glad to make your day ......keep up the good work...its gettin there...
Year & Model:
'04 Coupe
Color:
MSG (duh!)
woops thought you were a MS
