Correct Tire Pressure
Old Oct 9, 2006 | 12:58 PM
KnightRider02's Avatar
KnightRider02
Default Correct Tire Pressure
I have Toyo T1S's and the tire says the max inflation is 50psi. I know that you don't need 50psi in the tires. What would be the happy medium that will yield the best performance and least treadware?
J
Old Oct 9, 2006 | 01:06 PM
Bill Vett's Avatar
Bill Vett
Look on drivers door for proper inflation. Start with 30 psi cold and keep an eye on tires. Center wearing to much air, outside not enough air. (add 2 lb.) The side wall psi is just the max for that tire. The door psi is for the weight of the vehicle.
Old Oct 9, 2006 | 01:46 PM
rws.1's Avatar
rws.1
You want to be around 30 psi.
I prefer 28 psi cold which ends up around 32 psi warm...
Seems to give me the most even tread wear
Old Oct 9, 2006 | 01:49 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
30 PSI according to the sticker on the driver door
Old Oct 9, 2006 | 02:29 PM
Falcon05Dad's Avatar
Falcon05Dad
32psi at running temp is perfect with T1S's. The grip is good and they wear well.
Greg
Old Oct 9, 2006 | 02:48 PM
kderderian's Avatar
kderderian
If you are going to a track day about 36 psi warm. Street 30 to 32 psi works great.
Old Oct 9, 2006 | 02:53 PM
csexton's Avatar
csexton
Chuck
Old Oct 9, 2006 | 03:20 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
St. Jude Donor '05 thru '19
What is that in Canuck, 207 kPa?
Old Oct 9, 2006 | 03:58 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Several members use 30 psi warm and have had trememdous success. This will give the best combination of ride and tire life. This will however require a bunch more work on your part as you will need to adjust your monitoring habits as the weather and outdoor temps change. 30psi cold as indicated on the door panel is a safe "no one gets hurt" approach by the manufacturer.
Old Oct 9, 2006 | 04:27 PM
Zilla's Avatar
Zilla
Hell I don't know i drive around in MPH all the time.
Old Oct 9, 2006 | 04:39 PM
OhioDave's Avatar
OhioDave
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
I set mine at 34 psi after warming them up. I make sure all 4 tires are reading exactly the same after they are hot. You can watch the pressure sensors start going up as the tire temps. increase and the goal is to have all "4" reading the same psi, once they are up to temperature.
Really don't care what the psi is while their cold setting in my garage, but it is right around that 30 psi cold setting to have them reach 34 psi warm.
Works for me, all my tires are wearing equally.
Old Oct 9, 2006 | 08:14 PM
peter p's Avatar
peter p
Put Nitrogen in the stock GY runflats last weekend...tire guy filled them up to 44psi...max for the tire...so I could bleed them down. Took them down to 30 psi cold per the door label.
The tires with the nitro should have less pressure fluctuation and run cooler since it is dry.
I understand you should get the same effect with an in-line air dryer...water/moisture appears to be the main culprit with air pressure fluctuation.
Old Oct 9, 2006 | 10:36 PM
blacksedan87's Avatar
blacksedan87
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Why - isn't that slower?
Old Oct 10, 2006 | 12:09 AM
Old Oct 10, 2006 | 01:56 AM
b98's Avatar
b98
30 cold.
Old Oct 10, 2006 | 07:31 AM
Tom/99's Avatar
Tom/99
I run 29 psi in the rears, and 31 psi in the fronts.
Old Oct 10, 2006 | 09:07 AM
Zilla's Avatar
Zilla
See if I drive in KPH my top speed is 300 KPH, when in MPH it is 300 MPH according to my speedo(Not the swim suit)
To Correct Tire Pressure
Old Nov 8, 2006 | 10:35 PM
Larry Salsman's Avatar
Larry Salsman
I am thinking about getting a set of TOYO. What do you think of them?
Old Nov 9, 2006 | 12:18 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...with the exception that I keep mine at 30-31 hot...not 30 cold...ask the man that knows tire pressure...~cough~Evil-Twin~cough~
Old Nov 9, 2006 | 12:38 AM
BuckyBoy's Avatar
BuckyBoy
St. Jude Donor '06
That's the max for hauling, etc. I would follow whats on the drivers door... seem to be happy with 28 all around.
