1997 headlight motor problems...help
Old Oct 10, 2006 | 01:36 AM
uncle slim's Avatar
uncle slim
Default 1997 headlight motor problems...help
when i turn headlights off and light goes down it make a bad grinding noise... do i need to replace the motor or can i do something to fix this???
Old Oct 10, 2006 | 06:16 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Don't worry, this is a common problem on C5's. One of your headlight gears (plastic from the factory) has stripped. There are some very good brass replacement gears available here:
http://www.rodneydickman.com/retail_new.html
From the home page click on the tab at the top labeled electical, scroll down the page to Headlight and look to the right for the Other Vehicles. Click on 1997 -2004 C5 Corvette Brass Headlight Gears. You are fortunate in that the '97-99's had a removable cover on the head light motor. Newer motors will have to be "Broken free" to replace the gear. The change should take you about 30 minutes or so.
Paul
