Started my Z06 on the weekend (with a whooping 6000 miles on it), and the "Low Oil Pressure" banner came up on the DIC, and the oil pressure gauge read absolutely zero (but did flick up and back upon initial startup like all the gauges do). Had it flatbedded to GM dealership this morning, and they received notice from GM that they have had problems with the oil pumps. I don't know if this just affects the 2001 Corvettes, but if you get a similar message TURN YOUR CAR OFF IMMEDIATELY because there really is no oil being pumped.
For me the timing fits nicely though, as I have been meaning to take it in to get it set up for the oil consumption test anyway.
After looking at the C5 Tech/Performance forum, it appears that others are experiencing the same problem. My dealership mechanic said he called GM Tech and they told him that they knew of the problem and told him to replace the pump. He said he didn't know for sure, but that it is probably the pressure release valve sticking in the oil pump. I should be getting it back today, so my fingers are crossed!
imp zog -- glad to hear they fixed you up OK. Did the dealer say anything about if this was an 01 only problem? If GM knew about it for awhile, then I'm thinking the 02s had this fix going into production (I hope :D).
This is one thing that bugs me about GM. The C5 is in its 6th year of production, and crap like this still shows its ugly head. Maybe its more related to production errors than design errors, and if so you would think GM would tighten its QA alittle bit in the manufacturing arena. I think this is where US and European/Japan manufacturing practices deviate from each other.
From a similar thread going on right now in the C5 Tech/Performance group, it appears to not just be isolated to the 2001 nor to just the Z06. They were good about replacing it, so I have no beefs with GM about it other than that maybe this should be a service bulletin so as to catch it before people blow up their engines.
