Can anyone recommend alignment spec's for my 01 Z06? I just bought a new set of Kuhmo Ecsta V710's and am heading for the track (NHIS Road Course) this weekend. I have lowered the car almost as low as it goes. I will be changing back to street tires & wheels and still want to drive on the street. I'm mostly concerned about getting the most track time out of the tires.
I run 4/5 HPDEs a year so I want track performance but don't want to chord street tires in 3000 miles so here's what I run.
Front
-1.3 degrees camber per side
+6.9 degrees caster per side
0 toe (very very very critical to low tire wear)
Rear
-.9 degrees camber per side
1/16th" toe-in per side or 1/8th" sum toe-in.
Car handles much much better yet I still get very very long street tire life. The fronts do wear a little more on the inner 1/2 but I still get over 20,000 miles out of them.
Front
Rear
I run almost the same specs for my commuter/trackday Z06. My current set of R2's are almost bald and are worn fairly even across the tread. The fronts seem to last a little longer than the rears. I dont' get anywhere near 20,000 miles. 2 trackdays and about 2-3,000 street miles.
Dog... that's because you're running R2's!!! Normal street tires will last. I run Hoosiers at the track.
Steve... I think the front is like -.7 degrees camber max, but like all cars it's an "acceptable" range, not specific specs. So... in short I don't know all the stock specs.
It is really easy to reset the toe on these cars at the same time you are changing tires. I used to run zero toe on the street and then crank in 1/2 a turn of toe out into the front on the track. Just mark you tie rods to the zero position and match mark the links and you can reset it in a couple of minutes. Nail polish (rob your wife or girl friend) or a bit of white paint make it easy to see where the zero point is.
Latey I have been running about 1/2 a turn of toe in per side on the street and then crank in the 1/2 turn of toe out at the track.
