When you're getting ready to work on the car which battery cable should you disconnect? Does it matter? Is their a safety issue in regards to the car or my own personal well being?
I typically disconnect the ground cable first and then the positive cable. Key is that they have memory and want to go back where they were so you need to make sure that does not happen.
I'm glad you asked this question ROCKnROLL, as I have been wondering the same. I've always disconnected the positive first, then reconnected the ground first, but I'm not sure that's correct or where I learned it.
On a related note, when dis/reconnecting the cables, they make intermittent contact with the terminals as I'm tightening, sending short bursts of power through the electrical system. I feel like this cannot be good for various electrical components, and I'm pretty sure it led to my recent column lock nightmare. Do you know a better way, or am I needlessly obsessing? TIA
You should always disconnect the negative cable first. The reason for this is if you touch your wrench to ground when taking off the positive cable off first it will short causing sparking or possible explosion. If the negative cable is disconnected first the circuit is not completed when taking off the positive cable.
You've not had a truly exciting day until you've seen your wrench short to ground, making a big spark and instantly welding itself to the rest of the car. The next few seconds, things get really interesting...
If your only disconnecting one battery cable, make it the ground cable. No chance of shorting it out to something and burning it up..... unless it is the possitive terminal.
I learned the hard way in the 60's. I tried disconnecting the positive first on a 65 Vette and had on my high school class ring. With the wrench on the positive terminal and in the palm of my hand, I turned the bolt and my ring touched the engine block. Not only did it melt my gold ring, it blistered a new ring all around my finger. I don't do it that way now.
Always negative First. This really became important with the start of computer cars. The idea is to remove negative first and positive last. The reasoning for this is to prevent a voltage spike that can harm the computers. There have been voltage spikes that have been measured over a 100 volts, when that happens, good by computers. When reinstalling the cables, Positive First Negative Last. When you reinstall in this order, voltage spike goes to ground.
...along the same lines, always remove any jewelry like watches/rings or body piercings if you don't disconnect the battery.
It's never happened to me...however, I've seen images of people who failed to do this and not only welded their favorite wedding ring to their car, but got really nasty burns as well.
