Sterring Column Lock Bypass problem.
Old Oct 20, 2006 | 12:42 PM
wicked23's Avatar
wicked23
Navigator
Default Sterring Column Lock Bypass problem.
I installed Corvettes of Houston's column lock bypass and installed it, but the message on the display still reads sterring column lock when I start the car up. Isn't that supposed to go away?
Old Oct 20, 2006 | 12:58 PM
seawolf's Avatar
seawolf
I called them (CoH) when mine locked up and they told me I had to get it towed to the dealer and fixed by them first and than install the CLB.
Old Oct 20, 2006 | 01:10 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
it was locked and then you installed it? that will not unlock it.
do whatever you can to get the column unlocked and then reinstall it.
Old Oct 20, 2006 | 01:11 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Is the column unlocked? Just displaying the message?
Old Oct 20, 2006 | 02:31 PM
wicked23's Avatar
wicked23
Navigator
column is not locked it is just displaying that message!
Old Oct 20, 2006 | 03:52 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
From the C5 Tech sticky:
I still get the "Pull Key and Wait 10 Seconds" message and "Service Steering Column Lock" message? What do I do now?
A1 Sometimes the latching relay in the CLB can get out of sync sending the wrong status to your BCM. This has happened to a few folks even with the CLB installed. The CLB latching relay gets out of sync with the BCM possibly due to shock, vibration or relay contact bounce during switching which confused the BCM. The CLB does not physically know which state it should be in; it only switches from one state to the other when it receives a signal from the BCM. The BCM can be reset by pulling Fuse 23 and waiting 10 seconds.
A2 Check to make sure Fuse 25 in passenger footwell is good.
A3 Verify the black wire to your ECL or CLB is grounded (zero ohms resistance).
A5 Verify the green wire to the ECL or CLB is shorted to ground while in the "UNLOCKED" position and +12Vdc while in the "LOCKED" position.
A6 If you get the "Pull Key and Wait 10 Seconds" message but no "Service Column Lock" message, it could be your security system and related to your key pellet.
Old Oct 20, 2006 | 04:24 PM
wicked23's Avatar
wicked23
Navigator
Is the fuse panel under the carpet on the passenger side near the computer?
Old Oct 20, 2006 | 04:54 PM
GRAY BEARD's Avatar
GRAY BEARD
YES same area. Pul floor panel and fuse box is right next to puter.
Old Oct 20, 2006 | 05:13 PM
wicked23's Avatar
wicked23
Navigator
ok thanks!
To Sterring Column Lock Bypass problem.
