[Z06] Wheel Cleaner+++
Old Oct 25, 2006 | 01:07 PM
hot1_z06's Avatar
hot1_z06
Cruising
Default Wheel Cleaner+++
Hi all !!!
I am new to this forum just wanted to let you know about a wheel clean I just found that you may know about. Dupont Teflon wheel cleaner. Those wheels on my 07 Zo6 get a lot of brake dust and are so deep to clean. Just spray on and hose off works great! also safe for paint,, glass etc. I tested it on the paint on my 06 Z06 before I traded.
Old Oct 25, 2006 | 08:12 PM
Z06PDX's Avatar
Z06PDX
where do you get it?
thanks!
Old Oct 25, 2006 | 08:53 PM
Z06_Bob's Avatar
Z06_Bob
You can buy it online at Midway Auto Supply or Autobarn. I heard that Ace Hardware may carry it....going to check it out this week.
Z06_Bob
Old Oct 25, 2006 | 09:11 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Watch the overspray, believe it or not, there have been more than a few front reverse leaf springs that have delaminated. GM says it is because of wheel/tire cleaner over spary deteoriating the leaf. I know personally of a friend of mine with an 04Z16Z06, in NJ that has had this happen, and GM will not fix under warranty. Not trying to hijack this thread, do a forum search, there have been others.
Old Oct 26, 2006 | 10:02 AM
zcobra1's Avatar
zcobra1
I use Simple Green to loosen the dust- never had a problem removing the grime- it is biodegradable and will not harm your car....
Old Oct 26, 2006 | 11:20 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Sounds like an advertising troll
Old Oct 26, 2006 | 12:04 PM
Z06-Nomad's Avatar
Z06-Nomad
And even if he isn't, Soap and Water is the way to go. Has worked great for centuries and doesn't hurt anything.
MD
Old Oct 26, 2006 | 01:00 PM
Cobra4B's Avatar
Cobra4B
Spray on hose off never works to the standards we keep for our vettes... however if brake dust is especially nasty it can help loosen it up.
Go away :
Old Oct 26, 2006 | 01:32 PM
Z06-Nomad's Avatar
Z06-Nomad
Go away :
Try Carbotech pads for the track. They dust plenty, like any good track pad, but it comes right off with the same soap you wash your car with. Ceramic for the street and you are all set
MD
Old Oct 26, 2006 | 03:46 PM
Cobra4B's Avatar
Cobra4B
Personally I run ceramics on street and Wilwood H's on track.
Old Oct 26, 2006 | 03:56 PM
Vettez16's Avatar
Vettez16
Water and Maquires mild car soap. I saw the delamination that was mentioned earlier. Not good! I stick to my extra soft bristle brush now. A little extra time, but I will sleep at night.
I cheat once in awhile with simple green, but its more like a blessing even though its probably safe. Failure on a high speed run - OMG!
Old Oct 26, 2006 | 06:18 PM
J Z06's Avatar
J Z06
car wash soap+water works fine for me.
Old Oct 26, 2006 | 07:05 PM
Joy of 6's Avatar
Joy of 6
I take my wheels off and claen them. NO delamination at all!
Old Oct 26, 2006 | 07:28 PM
briann510's Avatar
briann510
Simple Green works just fine. Spray it on and hose it off. No need to buy expensive "special" wheel cleaners at all.
Old Oct 26, 2006 | 10:57 PM
GeorgeZNJ's Avatar
GeorgeZNJ
I forgot to mention that I'm so dam lazy, I took my chrome wheels off, and put the stock gunmetal ones on. The dust(and there is a lot) that my polymatrix pads make doesn't look too bad on them
To Wheel Cleaner+++
