Just installed one from Elite Engineering. Simple install. Only issue was the center spoiler would not re-install without losing the fold back capability. Since I live in an area where it drags several times a day, my solution was just to cut down the top of the spoiler piece a couple inches and now it just touches the shield and fold backs fine from the stock angle. Probably would have been a good idea to place a strip of duct tape at the back of the shield from above to help maintain positive air pressure after shaving the top of the spoiler down (may go back and do it later), but most of my driving is around town and I doubt the center spoiler has any real contribution at city speeds.
I had some fibergalss window screen left over from a doorwall screen I re-did.
So I went down to Home Depot and bought some screen framing and a package of 5/16 mill screen corners.
Brought it home and cut the framing so it was 28X11 outside dim. when assembled, then installed the screen with screening spline.
Removed the center spoiler and cut the top edge off, reinstalled it and tucked the rear edge of the screen frame between the support and the radiator.
Then attached the front to the inside of the front facia with springs so it will deflect in the case of road gators (lots of them in Fl.)
Net result it traps almost everything and is self cleaning for the most part, and it also allows the spoiler to deflect.
Total cost about $5.00 and it's been on for the last 3 years!
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
and how easy is it to install, what did you have to do?
I'm trying to decide if I should buy this however if the installation is too difficult then I am having second thoughts.
Thanks.
I bought mine from Mid America motors and i put it on myself it is very easy and used the same bolts that are under the front of the car to put it on.And if a woman can do it so can you
I installed one of Elite's screens. Great product, doesn't vibrate or rattle because it's a quality piece professionally manufactured. Easy to install and it looks great too. You get what you pay for.
