driving lights
Old Oct 27, 2006 | 06:28 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default driving lights
can anyone tell me how to adjust the aim of the stock driving lights...
Old Oct 27, 2006 | 09:58 PM
GOZ2FST's Avatar
GOZ2FST
I can't - but here's a ttt for you.
Someone out there knows.
Old Oct 27, 2006 | 10:00 PM
Sportsdude's Avatar
Sportsdude
Hope this helps
Old Oct 28, 2006 | 12:28 PM
hdff's Avatar
hdff
Originally Posted by Sportsdude
Hope this helps
thanks but i was wanting to know how to adjust the little round driving lights not the head lites. i need to aim mine up some...
Old Oct 28, 2006 | 12:58 PM
2KFRC5's Avatar
2KFRC5
Upper outside of each fog lamp is a small hole in which is the adjusting screw. #15 Torx.
To aim, measure centerline of lamp to level ground. At a distance of 25' on a wall, garage door, or whatever, mark that measurement. The center of the high intensity part of the beam should be approx. 4" below that mark.
Old Oct 28, 2006 | 01:01 PM
CMYC4GO's Avatar
CMYC4GO
Wow! That's good to know, as I was wondering the same thing. I could go spotlighting for coons with one of mine. The right one lights up the treetops very well at night!
Old Oct 28, 2006 | 01:02 PM
omarcoolguy's Avatar
omarcoolguy
i can just push mine up and down.....so stick ur hand in there and give it a lil push
Old Oct 28, 2006 | 01:08 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The screw makes the position locked,they are sping loaded... you can push the light up but it wont stay... using the torque screw will insure its position... BTW most of the Fog lights come from the factory pointing down... a simple adjustment will make them work much better... Mark a line visually on a garage door or wall with the car level... adjust the fogs to 4 in/ below this mark. the should rest between the low beam line and the high beam line.
Bill aka ET
Old Oct 28, 2006 | 02:26 PM
hdff's Avatar
hdff
thanks everyone
Old Oct 28, 2006 | 04:11 PM
bighank's Avatar
bighank
While you're at it... Replace the Stock 889 or 893 37 watt bulbs with a 885 50 watt bulb. Almost as bright as headlights. Mine are Sylvania at a local parts dealer and cost less than $5 each. Can reach in with headlights open and change em without unscresing the cover shield s explained in the GM Manual Have Fun BIGHANK
To driving lights
