Key FOB Problem!!!!
Old Oct 31, 2006 | 09:48 AM
glerma's Avatar
glerma
St. Jude Donor '05
Default Key FOB Problem!!!!
I keep having to resynchronize my keyless entry remote to my car. EVERY time the car is parked for a while... I cannot unlock it with the remote until I hold the LOCK and UNLOCK for longer than 7 seconds (to reprogram) This usually works and I can then use my remote... but the next time I return to my car... The remote will not unlock the car and I have to do the process again.
I have already replaced the battery in the remote. Does anyone have any ideas??? This is very irritating. BTW... my car is a 2000 6-speed convertible.
Old Oct 31, 2006 | 10:00 AM
timemender's Avatar
timemender
Unless you are in “programming mode” through the DIC (the car’s computer), simply holding down the two buttons on the remote does NOT reprogram the fob to the car.
Sounds like you need a new fob. Corvettes came with two fobs. Do you have the second fob? If not, get a spare and try using that fob for a while, as a test to eliminate the fob as the problem.
Old Oct 31, 2006 | 10:05 AM
CMYC4GO's Avatar
CMYC4GO
You may have to have your car re-learn your fob, and to do this, you do:
1. Turn key to the on position.
2. Press the option button until the DIC screen is blank.
3. Hold the reset button for 2 seconds.
4. Press the reset again, and you should see something like "Learning Fob 1" or something to that effect.
5. Push both the lock and unlock at the same time on the fob for 15 seconds, and it should be reprogrammed to the car.
Pretty easy stuff, actually.
Old Oct 31, 2006 | 10:10 AM
BadYellowCorvette's Avatar
BadYellowCorvette
Try to reprogram it throught the DIC if that does not work it your key fob. I've already been there done that
glerma's Avatar
glerma
St. Jude Donor '05
Thanks for the info... I followed the "Resynchronizing Your Transmitter" instructions in the owners manual page 2-11. It states that if you hold the Lock and Unlock buttons together for longer than 7 seconds... The horn will chirp and the remote will be synched. I do this and it works... but I have to do it every time.
Old Oct 31, 2006 | 10:31 AM
Vic Montaner's Avatar
Vic Montaner
I think you missing the point......
Dont resynchroniz your transmitter....re-instruct or re-learn your fob. Follow the directions in your manual or look above t "CMYC5GO", he listed the steps for you.
Old Oct 31, 2006 | 10:42 AM
glerma's Avatar
glerma
St. Jude Donor '05
10-4 on that.... Thanks for the input guys! I will try to reprogram through the DIC. Any sources for reasonably priced remotes if my remote is bad? I have only one remote.
Old Oct 31, 2006 | 01:48 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Ken Fichtner or Fred Bean's (both forum vendors) or your local dealership.
You might also try cleaning the contacts inside your fob before buying a new one. Some people have cleaned the contact points with a pencil eraser, but I prefer electrical contact cleaner spray. Spray a small amount on a soft cloth and gently clean the contacts under each rubber button. Also clean the contact areas for the battery. After you do this you will need to re-program (re-learn) the fob again thru the DIC.
Cleaning helped my fob for a while, but I eventually had to buy a new one.
Old Oct 31, 2006 | 01:53 PM
black2KC5vette's Avatar
black2KC5vette
Default Friggin FOB
Might as well just buy a new one. When they act up, they're goners.
B2KC5V
Old Oct 31, 2006 | 03:47 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
B2KC5V
99.9% of the time a new one solves your problem.
Old Oct 31, 2006 | 04:25 PM
IrishJoker's Avatar
IrishJoker
New FOBS are only around $35-40 bucks. Buy a new one.
Old Oct 31, 2006 | 05:06 PM
duckvett's Avatar
duckvett
Not for a 2000 - I paid $90 for my new one.
2000 fobs are different than 97-99 and 01-04.
Old Oct 31, 2006 | 05:10 PM
Bill Vett's Avatar
Bill Vett
$70.'s to $75.'s for a 2000 fob used, new is around $125.'s . The 2000 fob is different than the 97 to 99 and the 2001 to 2004.
Old Oct 31, 2006 | 05:13 PM
bighank's Avatar
bighank
Default key fob
Had same symptoms. got different fobs on fleeebay for 50 - 70 dollars.
Need FCCID AB00216T for a 2000 later ones WON'T WORK. Passive won't work on a 2000 lucky you its a PITA.
Old Oct 31, 2006 | 07:32 PM
Mine did the same thing recently. Ended up getting a new fob and that solved the problem.
Old Oct 31, 2006 | 07:39 PM
glkfam's Avatar
glkfam
Default Might try to bend tabs on remote
Hi,
You may want to try and bend the little tabs up that are in the battery compartment inside the FOB. It is possible that the tabs from the battery are not making good contact to the circuit board inside the FOB. Obviously be careful not to bend them to far up as to break. You may also want to clean the place on the circuit board where these tabs from the battery hit the board. Possibly the connection pad could be gummed up. If you don't have contact cleaner, try rubbing carefully with the eraser from a pencil. Just do it carefully and then make sure all the eraser remains are completely removed. Then reprogram the FOB through the DIC. It might be worth a shot.
To Key FOB Problem!!!!
