Cargo net install?
Old Nov 1, 2006 | 08:33 PM
grey 79's Avatar
grey 79
Default Cargo net install?
Have cargo net and 2 connector-like pieces , that came with
04 Coupe--- no instructions.
already have cargo shade installed.
Can this net be installed with shade in place? ; if so, how is it done?
Anyone use theirs?
TIA
Old Nov 1, 2006 | 09:14 PM
Bubbletop409's Avatar
Bubbletop409
There are four "t" shaped nuts that screw onto existing studs already in place. Look in the area adjacent to the side storage compartments, you should see some gold colored threaded studs, the "t" nuts go on them, and net attaches to them. Mine came with a little pouch to hold all the optional stuff for the storage area.
Old Nov 1, 2006 | 09:17 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
There are two connectors up under the ledge slide you hand under the edge and you will feel them.
Old Nov 1, 2006 | 09:21 PM
Zilla's Avatar
Zilla
Found a thread for you that has pics
http://forums.corvetteforum.com/show...89&postcount=3
Old Nov 1, 2006 | 09:37 PM
Bill Dearborn's Avatar
Bill Dearborn
The net on my 97 fastened in 4 places two at the top and two at the bottom. It came with two screw on caps and the other two were already on the car to hold the inner compartment panels in place.
Bill
Old Nov 1, 2006 | 10:31 PM
Blue Lion's Avatar
Blue Lion
The net and the shade can be used at the same time.
Old Nov 1, 2006 | 10:39 PM
grey 79's Avatar
grey 79
Thanks, makes sense now.
2 front loops go to upper hooks; 2 back loops to lower hooks.
Old Nov 2, 2006 | 12:54 AM
SultansDiamond's Avatar
SultansDiamond
The pics were great, but I have an '02 Vert and can't find them on my car? There was a net in the trunk when I bought it - not installed.
Are vert's suppose to have 'em?
Thanks,
Old Nov 2, 2006 | 07:59 AM
redmichvette's Avatar
redmichvette
Yes. My 98 vert has one and it is the same as the one referenced in the thread from Zilla.
Old Nov 2, 2006 | 08:23 AM
dndrsn's Avatar
dndrsn
Thanks,
I have an '02 vert and the net attaches to the back panel.
unlike a coupe which attaches underneath the quarterpanel. pic copied from ET's POST
I believe a vert net is shorter and will not fit on a coupe.
Old Nov 2, 2006 | 09:56 AM
redmichvette
Old Nov 2, 2006 | 11:22 AM
rgjaglowski's Avatar
rgjaglowski
After reading these I checked my car and found out that I only have three of the four plastic screw on T-nuts that I need. Does anyone know how to get one of these. My dealer says the only way I can get one is to buy a complete safety net kit from GM for $57+. This makes for a pretty expensive T-nut!!!
Old Nov 2, 2006 | 11:25 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
My Z06 has the t-nuts on the back panel like the vert too... I belive there's 2 different nets... the coupe one is wider.
Old Nov 2, 2006 | 01:36 PM
SultansDiamond
Alrighty then!
Thanks guys I see where the vert's attach. Figured as much as those nuts are the only possible option.
Damn I love this fourm.
To Cargo net install?
