Update On Weird Noise!! : (
Old Nov 2, 2006 | 06:47 PM
thegame's Avatar
thegame
Default Update On Weird Noise!! : (
Last week I posted this thread http://forums.corvetteforum.com/show....php?t=1535213
At first I thought it must be the springs making those noises but after tonight I do believe it's something entirely different. I took the car (03 z06) over to my cousins shop and went up with the car on the lift so I could rev it up a little and he could look for the noise. I'm going to try to explain this the best I can since I'm not exactly a car mechanic myself Right by where that spring is and around it is the catback exhaust; but underneath that is like a shield that needs to be taken off to get to the tranny ?? I can see little pebbles stuck and wedged on the sides of this and I'm assuming that if there are those two there are probably a few others that I can not see but I sure can HEAR I hope this kind of makes sense to a few people as it is kind of hard for me to explain it correctly on here. I will take it back to him next week and we're gonna take this off and see whats up. Does anyone have any good pictures of the underbody of the C5 ? Maybe that will help ?
Old Nov 2, 2006 | 07:52 PM
thegame's Avatar
thegame
I suck that bad at explaining
Old Nov 2, 2006 | 07:59 PM
502ci's Avatar
502ci
It was a bad attempt at explaining it but I undrstood every word and know right where you are talking about...
Old Nov 2, 2006 | 08:02 PM
thegame's Avatar
thegame
Thanks and yes I know it was Have you ever heard of this happening before ?
Old Nov 2, 2006 | 10:09 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi thegame -
If it is the springs on the h-pipe hanger, you can use a crowbar to "adjust" the L-bracket to tighten the spring pressure as mounted.
JTAllen just brought his car out a couple of weekends ago and we put his up on the lift - he had the same noise you seem to be hearing.
We bent the brackets slightly to put more preload on those springs and he has been a happy camper since.
I think you are looking at the clutch / torque converter inspection cover - I think if there were pebbles in there you'd really be hearing something!
best regards -
mqqn
Old Nov 4, 2006 | 08:35 PM
briansi91's Avatar
briansi91
the pebbles are in the torque tube closeout panel
the panel that is above the h pipe that has a million 8mm bolts holding it in place
Old Nov 4, 2006 | 11:59 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
36
Peace
Chip
__________________
..................Click for
To Update On Weird Noise!! : (
