Coolant Temp ?
Old Nov 5, 2006 | 01:15 PM
RayCE's Avatar
RayCE
Default Coolant Temp ?
What should the normal coolant temp be.? What is the range ?
My temp is from 189 to 208, is this normal?
RayCE
Old Nov 5, 2006 | 01:16 PM
CMYC4GO's Avatar
CMYC4GO
Mine runs a constant 196 at road speeds.
Old Nov 5, 2006 | 01:36 PM
vetred's Avatar
vetred
The ABSOLUTE First thing you should be doing is LOWERING your temps!!! Dont listen to ANYONE who says otherwise!! Lets review,........ Cold air = dence air dence air = HORSEPOWER, horsepower= GOOD!!!! AND AS WE ALL KNOW GOOD = ,.....HORIWOOOOOOOOOD! You must learn that just becouse someone has the where with all to have something, doesnt nessaraly mean they have a simple clue as how things actualy work!!! Do yourself a BIG favor, Go to the TRACK (drag or roadracing near you) next spring you will see EVERYTHING and you will learn EVERYTHING and you will KNOW when your reading another freeken poser!!!
Old Nov 5, 2006 | 05:42 PM
RayCE's Avatar
RayCE
Thanks........
Old Nov 5, 2006 | 06:09 PM
kevin40zx's Avatar
kevin40zx
When stock my temps were around 198 while cruising and sitting still they would creep up to around 225. This seemed high to me at first but it is normal. GM used these high temps to control emissions.
Old Nov 5, 2006 | 07:08 PM
Tigershark3's Avatar
Tigershark3
190-192 when the car is on the move... If it's a hot day and I'm stuck in traffic I've seen it go to 210-220.
Old Nov 5, 2006 | 07:20 PM
65GGvert's Avatar
65GGvert
The answer to your question is absolutely normal for COOLANT temp. I don't know what temp your air should be.
Old Nov 5, 2006 | 07:24 PM
DeeGee's Avatar
DeeGee
Perfectly normal
Even in the height of the Vegas summer I made about 210 in traffic.
Old Nov 5, 2006 | 07:41 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
GM engineers know more than I do about these machines.
Old Nov 5, 2006 | 07:43 PM
Mine stays around 196 degrees. That said, there is nothing wrong with the temps you are seeing.
Old Nov 6, 2006 | 11:48 AM
EHS's Avatar
EHS
Coolant's nice, but the oil temps need to be above 212 F.
Old Nov 6, 2006 | 02:50 PM
RayCE's Avatar
RayCE
Default Thanks
Thank you all for the information................
Ray
Old Nov 6, 2006 | 03:02 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
On a hot day I see about 190°. Normal cruising and on the highway is stays between 170° and 180°.
The Hypertech 160° thermostat and tuning might have something to do with that though.
To Coolant Temp ?
