hyper turn signal (right blinker only)
Old Nov 6, 2006 | 10:40 AM
drace99's Avatar
drace99
Default hyper turn signal (right blinker only)
New problem...turn on my right blinker/turn signal...it goes really fast. The left one is normal. Could this be a short or ground problem? Anyone else had a similar problem?
Old Nov 6, 2006 | 10:45 AM
wt2ga's Avatar
wt2ga
Check for a burnt out bulb on that side..
Old Nov 6, 2006 | 10:59 AM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Yep, sounds like you DRL is out on that side...
Old Nov 6, 2006 | 11:00 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Old Nov 6, 2006 | 11:48 AM
rws.1's Avatar
rws.1
turn your way(hazard) flashers on and off a couple times and then try your blinker...
If it is not a bad bulb it could be the start of a very common problem with the flasher
Old Nov 6, 2006 | 11:54 AM
pointu's Avatar
pointu
From: sometimes the lights are shining on me, other times i can barely see minnesota
bet thats it
Old Nov 6, 2006 | 01:37 PM
DeeGee's Avatar
DeeGee
Thats your problem
Don't forget the DRL bulb is dual filament for both DRL and turn signals. They're on seperate circuits so one can be out when the others working
Old Nov 6, 2006 | 02:51 PM
drace99's Avatar
drace99
Default thanks
I will try replacing the bulb. Any idea of a part number?
Old Nov 6, 2006 | 02:54 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
4157NALL
Make sure it is the NALL which is the amber one or else you will get the clear ones (which look cool too!).
Glen
Old Nov 6, 2006 | 04:31 PM
kromberg's Avatar
kromberg
Have you checked the turn signal fluid level? Fast blinking is a sign of the fluid getting low and air getting into the line.
Keith
Old Nov 6, 2006 | 04:50 PM
RFS-Z06's Avatar
RFS-Z06
Old Nov 6, 2006 | 06:53 PM
NOLAVette's Avatar
NOLAVette
Shouldn't this topic be a "Sticky" post either in this forum or the C5 Tech forum because of the extreme frequency of its appearance? It's such a very common problem with a variety of diagnostic steps and fixes that are all very good.
The burned out bulb due to water intrusion into the socket because of a cracked lens housing seems to be the usual culprit. Followed by the coroded socket contacts, then followed by the defective Hazard/turn signal flasher module.
Old Nov 6, 2006 | 07:08 PM
ramez75's Avatar
ramez75
I am having the same problem for the past week. Is that one bulb that is for the blinker and DRL or they are 2 seperate bulbs and is there directions how to change them, is it something i can do in few minutes.
Ramez
Old Nov 6, 2006 | 07:56 PM
NOLAVette's Avatar
NOLAVette
One bulb. Dual filament. One for turn signal. One for DLR. 4157 nall or 3157 amber for both #s.
I can change a turn signal bulb in 2 minutes flat. I'm 6 ft, 250 # with larger than average arms.
Turn on headlights with switch-turn switch back one click. Headlights are off but stay open.
Unscrew the hood support bolt with the rubber bumper on top. Put your arm into the opening and remove the socket from the lens housing by pushing in the locking plastic thing and tuning a quarter turn. This is all done by feel.
When the socket is free, push the brake duct down away from the small oval opening in the front bumper. Pull the socket out through that opening and change the bulb. Reverse these steps to put it all back together. After you do it once it will only take about 2 minutes to do it again. No need to lift the car at all. I've had to replace 3 bulbs in the past 2 weeks. I'm getting pretty good at it now.
Old Nov 12, 2006 | 05:49 PM
wearitoo's Avatar
wearitoo
7th Gear
Default turn blub replacement
Thanks for the instructions, now if I could only get you to do it.
jon in miami
Old Nov 12, 2006 | 05:55 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It is a feature to let you know that one of the lights on that side is out! Let us know what you find
Thanks,Matt
Old Nov 12, 2006 | 06:51 PM
ramez75's Avatar
ramez75
NolaVette94 is right its easy once you figure it out, I changed mine for the first time yesterady it took me 5 to 10min to get it done, I had to find the plastic thing. No tools required other than a flash light if u r doing it at night
Ramez
To hyper turn signal (right blinker only)
Old Nov 16, 2006 | 10:02 PM
Blackie's Avatar
Blackie
I keep dropping bulbs in the opening when I go to change them ( front turn signal ) . Anyone know how to get them out. I can see them through the lens.
Old Nov 16, 2006 | 10:04 PM
Zilla's Avatar
Zilla
Old Nov 20, 2006 | 09:08 AM
NOLAVette's Avatar
NOLAVette
All you have to do is push down on the brake duct just inside the opening (Smaller oval opening) below the lens. The duct tubing will disconnect from the opening and you just push down on it a bit to move it out of the way, and then you can pull the bulb socket out into the daylight to change the bulb and to inspect it for damage or even to replace it if needed.
