Need to replace the differential seals!
Old Nov 6, 2006 | 02:34 PM
Crash94536's Avatar
Crash94536
Default Need to replace the differential seals!
After a very fun day at the track I managed to get the differential/transmission a little hot. The result is oil leaking from the driver side seal on the differential.
I would rather do it myself than taking it to a shop. I will more than likely add both differential and transmission coolers at the same time.
Have any of you done this yourself?
Any special tools needed?
Thanks, Darryl
Old Nov 6, 2006 | 03:33 PM
rws.1's Avatar
rws.1
this thread might get you started...
I know there is at least antoher one with photos out there
http://forums.corvetteforum.com/show...ntial+leak+DIY
Old Nov 6, 2006 | 06:33 PM
Have had the differential seals in my car leak three times - but each time was repaired under warranty. Not sure what special tools, if any, they used.
Old Nov 6, 2006 | 06:47 PM
mike348's Avatar
mike348
Be sure to get the revised COVER AND O RING.
Old Nov 6, 2006 | 06:55 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
http://www.corvetteactioncenter.com/....php?qstId=225
http://www.corvettefever.com/howto/18978/index.html
http://mikemercury.home.att.net/342.htm
To Need to replace the differential seals!
