[Z06] Thinking hard about a cam....
I have easy access to 3 known mod shops:
1) 21 CMC
2) MTI
3) LG
I am looking at cam and oilpump only. (Oh yeah, probably better say I understand that I am looking at springs/retainers as well) Car is BONE stock except for blackwing. I would LOVE
to gain close to 100 hp (flywheel) with the swap. I know at one point there were some cams that would get you close. I like lopey idles and this is not a daily driver (she barely has 32K on her at 4.5 years old)Please provide me with input from your experiences with drivability, power, sound, blah blah blah
-Ed
Some items can be replaced since you are there.
Items to be purchased:
New cam
New chromemoly pushrods.
New springs, retainers and locks.
Double roller timing chain and gears. (for insurance)
New balancer bolt (stock bolt is a one time user)
New front seal in timing cover.
New timing cover gasket
Miscellaneous shop materials to be paid for:
Coolant
Engine assembly lube
loctite (blue and red)
Thread loc (white) for water pump bolts
gasket sealant for front corners of oil pan and timing cover
When I first did my cam swap, it cost me around $1000.00 doing it myself. The miscellaneous items are additional materials that a shop may charge you for in addition.
You are probably looking at 25 extra HP. The impact is more dramamtic when you have long tubes, which are good for X amount on the stock cam, but even a bit more with an aftermarket cam (Over and above cam only).
That may be a bit confusing, but to simplify with some made up numbers, the headers might be worth 25 HP on its own, and the cam might be worth 25 HP own, but together they are worth 65 HP. Same can be said for cold air intake and any other mods.
Give LGM a call they will set you up and wont steer you wrong, pick up a nice G5x3 on a 112 lobe and some pro long tubes...
I used my stock LS6 oil pump, and it's doing well so far.
You don't have to install a double roller chain. Just go to Thunder Racing and order a JWISS chain. It is just the chain, you use your own sprockets. It's made by Katech and is more then enuff for a head/cam car let alone just a cammed car.
If funds permit, I would get an underdrive balancer.
Your expectations of that much hp is a little high. You will have to add headers and an intake system to approach your goal. With my mods I put down 71rwhp over stock on the same chassis dyno.
Good luck and I hope this helps somehow.
Texas-speed's price $264.00, a 44% savings. They also have been excellent on shipping time and delivery also. If something isn't right, they take care of you with no questions asked.
Texas-speed's price $264.00, a 44% savings. They also have been excellent on shipping time and delivery also. If something isn't right, they take care of you with no questions asked. or heads/cam for $3595
EFI Live tuning by Don Kinder 'slowhawk'
Texas Speed LS6 CNC'd heads
TSP dual valvesprings, Titanium retainers, seats, valve seals
TSP Trend pushrods
Custom Comp Cam
LS2 timing chain
LS6 oil pump
GM gaskets(H20 pump, front cover, crank seal, oil pump oring)
GM MLS head gaskets
PowerBond Underdrive crank pulley
ARP head studs
Mobil 1/new oil filter
Dexcool coolant/distilled water
NGK TR55 plugs
Options: (prices listed are installed)
AFR heads: $1000
LS6 intake: $395
FAST 90/LS2 T/body: call
LS6/7 lifters: $130
American Racing headers: $1650 (2 week wait on AR headers, call for 1.75/1.875//3/2.5)
polished pwr/stg alt. bracket: $150
polished tensioner(new GM): $150
Borla/Corsa/B&B catback: call
Callaway Honker: call, (I should have one at the shop today)
This combo produced 447whp on 'Turbo1k' 2000 FRC w/ a FAST90/LS2 T/body
'My 00 vette' picked up 100whp using the above combo w/ an LS6 intake on his 2000 coupe
'Billdog350' is next up, similar setup with a 228/232 cam, not a bad way to freshen up a 115k mile motor
Stop by the shop, 1145 RT. 5, South Windsor CT, new Bendpak lift is installed
