New shift knobs and Base Plate
Old Nov 7, 2006 | 04:28 PM
HIGHRPM's Avatar
HIGHRPM
Default New shift ***** and Base Plate
After searching various vendors for a shift **** I liked...I decided that none were what I wanted. These are 2 of my favorites...both required making tooling and ALOT of fabrication time. I have about a dozen other designs, but these are the ones I use most of the time.
I never liked the big floppy shift boot, so I created a shift plate and a low tower to cover most of the space. These two pieces were cut from billet aluminum and powder coated. I went through several new boot designs before I settled on this one. I had it stitched at a local upholstery shop.
Old Nov 7, 2006 | 04:32 PM
stock c5's Avatar
stock c5
Man I love em... what are they?? Better yet, where are they??
Old Nov 7, 2006 | 04:47 PM
HIGHRPM's Avatar
HIGHRPM
The pistol grip shifter is a laminate of Gabon Ebony and aluminum....lots of tedious time with a die grinder. The diamond pattern is a laminate of about 20 pieces of white and black Corian. Lots of machine time and custom tooling to make that one.
Old Nov 7, 2006 | 04:58 PM
slverc5's Avatar
slverc5
IMHO, and no offense, I know you put a lot of hard work into it.
The first one, looks like somebody took a fillet or steak knife and jammed it into the shifter.
The second one is better but lose the playing cards design/look. I like the concept, just not the current design on the *****. Although the shifter plate looks cool maybe if you could color match it with the exterior color?
Ar you thinking of becoming a supporting vendor, any concepts on A4 shifters?
Old Nov 7, 2006 | 05:15 PM
HIGHRPM's Avatar
HIGHRPM
First of all.... you will never find a handle like that on any steak knife...the design is an agressive interpretation of the boring round pistol grip shifters that are very popular. I wanted something really different..... FYI I have many people requesting that I manufacture these and make them available. The diamond pattern has nothing to do with playing cards. Thanks for all the constructive criticsm.
Old Nov 7, 2006 | 05:22 PM
stock c5's Avatar
stock c5
ahh.. pictures are there now.
Old Nov 7, 2006 | 09:55 PM
slverc5's Avatar
slverc5
Relax, I apologize if I offended you. Like I said, I know how hard you worked on these pieces. If people love them -good for you. You showed it here so I safely assumed that you were asking opinions ( negative and positive). Second, I don't know how else to describe the second **** with the diamond pattern, the only thing that came to my mind are playing cards, that's why I used the playing cards term loosely to describe the second ****. I don't have your skills and I admire your work, but like I mentioned in my earlier thread - I like the concept of making your own shift plate/boot/**** combo just not your current design. I wouldn't say if you can make one for an A4 shifter if I wasn't interested. It seems I'm the only one with the negative feedback here. So- majority wins. More power to you!
Old Nov 7, 2006 | 10:35 PM
Half-Life's Avatar
Half-Life
I absolutely LOVE the pistol grip. Is it threaded/tapped or do you use set screws? Are you considering making more & becoming a supporting vendor?
Old Nov 7, 2006 | 11:03 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
If you do that .......I want to make sure you are aware of a CF rule:
http://forums.corvetteforum.com/show....php?t=1118158
Old Nov 7, 2006 | 11:10 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi HIGHRPM -
I like the shift plate and boot idea - very cool.
I made a similar pistol grip for a girlfriends Challenger back in 1980 or so.
Nice work - it would look great in a vintage mopar.
best regards -
mqqn
Old Nov 7, 2006 | 11:11 PM
JTJ's Avatar
JTJ
St. Jude Donor '08-'09
Nice work, I like both designs
Old Nov 8, 2006 | 06:26 AM
cenzo's Avatar
cenzo
Put me on your mailing list.
Old Nov 8, 2006 | 09:16 AM
Nice work on both. Very unique designs.
Old Nov 8, 2006 | 09:21 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Lots of workwmanship in those to shifter **** and they look great, I also like the custom boot
Old Nov 8, 2006 | 09:59 AM
TEXHAWK0's Avatar
TEXHAWK0
I like the machined base ring, and would like to know how it is held in place. The factory boot uses a plastic flex ring so there are no fastener holes, and I was wondering how you attached the new plate?
Old Nov 8, 2006 | 10:21 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
Great look and great work
Old Nov 8, 2006 | 11:09 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Man that's sweet!! But I'll bet the labor involved is huge. But good for you for fabricating one gorgeous shift ****. My hat goes off to you for the DIY.
To New shift knobs and Base Plate
Old Nov 8, 2006 | 11:11 AM
Nulltime's Avatar
Nulltime
That is DIY? Wow man nice job! (You could probably sell that design and make a mint hehe)
Old Nov 8, 2006 | 12:49 PM
HIGHRPM's Avatar
HIGHRPM
There is a threaded aluminum insert in both designs....both have threaded lock rings that locate/lock the **** at any height. I am considering the possibility of manufacturing several designs. The labor involved in hand producing them is enormous...they would have to be duplicated using CNC processes and low labor techniques...possibly offshore. I'm looking into what it. Thanks for the positive feedback.
Old Nov 8, 2006 | 01:06 PM
HIGHRPM's Avatar
HIGHRPM
The base ring ( I call it a tower) is held in place with 3 small set screws that are internal and below the base plate..... they are not visable. The boot is attached by an aluminum expansion ring that compresses the boot against the inside of the tower. The tower has a raised (square) internal ring that compresses/captures the leather boot with the expansion ring.
The base plate is attached with 6 L-shaped clips that secure the the plate to the underside of the tunnel. The underside of the base plate has 6 small square blocks and tapped holes.
