LPE battery relocation kits?
Old Nov 10, 2006 | 08:59 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Default LPE battery relocation kits?
I'm thinking of getting one of those Lingenfelter battery relocation kits. Anyone got one? How do you like it? How hard was the install? How hard would it be to undo it and how many scars would be left?
TIA!
Old Nov 16, 2006 | 11:14 AM
Gannet's Avatar
Gannet
St. Jude Donor '06
Anybody?
Old Nov 16, 2006 | 11:20 AM
GR8-LIFE's Avatar
GR8-LIFE
didnt know they made one. Whats the purpose? Are they relocating batteries with their applications?
Old Nov 16, 2006 | 11:41 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
the battery has a good amount of weight, relocating it to the rear of the car gives better weight distrobution to behind the rear wheels and increases traction.
i looked at it and couldent justtify the price, i want to relocate to the rear compartment but on the side and i dont think that box is nessisary, we will see, you can ge tthe cables at a sterio place and the connectors at pep boys
Old Nov 16, 2006 | 12:53 PM
Bubbletop409's Avatar
Bubbletop409
Check some of the mail order sites for a universal kit, does the same thing for a lot less cash. Just be sure to vent the battery box to the outside air, and that you establish a good ground where ever you attach the negative cable.
Old Nov 16, 2006 | 01:09 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
This is the link to the installation instructions for the LPE kit. http://www.lingenfelter.com/pdf/batt...nsversion2.pdf
I am thinking about doing it, but I think I can pick up the parts a lot cheaper than the LPE kit.
Seems like there would be a loss of power over the distance involved though.
Might be a good winter project.
Old Nov 16, 2006 | 01:31 PM
EatRice's Avatar
EatRice
There is no loss of power provided the proper gauge cables are used. It is ALOT cheaper to do it with a put together "kit" then LPE's. A standard battery discharges a deadly gas while in operation. Sealed batteries are not supposed to have a discharge but I have seen them discharge and explode. Any battery that is in the passenger compartment should be in a sealed enclosure vented to the outside of the car. Also there needs to be a high amperage fuse very close to the battery on the positive line. This is to protect the car from a possible fire if the power line is shorted to ground.
Old Nov 16, 2006 | 01:58 PM
mystifiedworm's Avatar
0mystifiedworm
Former Vendor
I have installed a few of the LPE kits. Their kit is well thought out and the parts are top notch. You must remember 2 things. 1.You get what you pay for. 2. You are going to try and mount a 15 lb battery in a fiberglass trunk opening, gonna need some bracing.
Chad
Old Nov 16, 2006 | 02:16 PM
EatRice's Avatar
EatRice
Chad
I agree but I do not see 400.00 worth of materials. I could see paying 400 installed but just for the kit it is way over the top.
Gannet...I just noticed you are close to me. I can help you with this if tou want. Here is a pic of the relocated batteries in my car.
Old Nov 16, 2006 | 04:18 PM
GR8-LIFE's Avatar
GR8-LIFE
FWIW Guys not long ago I heard the story of an owners battery in the rear casing a pretty big fire. Just remember the battery's close proximity to the gas tank when you do this. Just a thought
I could be wrong here, but Unless there is no room for storage in the engine compartment due to mods, I see no reason to move it. I suspect that if traction was a significant improvement due to battery relocation, then all the drag racers would be doing it. Of course, thats just a guess and I could be wrong
Old Nov 16, 2006 | 04:55 PM
EatRice's Avatar
EatRice
Fire would most likely be caused by the either battery exploding and spilling battery acid in the car causing the fire. Or if the power lead is shorted..the wire is so thick it will melt causing the car catch fire. That is why a fuse is used on the positive lead. I see no fuse in the LPE kit.
Old Nov 16, 2006 | 05:52 PM
b98's Avatar
b98
They do do it.
Old Nov 16, 2006 | 06:22 PM
jrprich's Avatar
jrprich
[/QUOTE]
Very neat work.
I hope you never get rear ended
How do you access these once the rear panel is back on ?
Old Nov 16, 2006 | 07:18 PM
EatRice's Avatar
EatRice
Thanks...I have no real need to access the batteries. I should never blow a fuse but those can be reached through the tail lights. I also have a quick release power block installed on the car. It is not seen in this picture. But it allows me to connect the car to a 110v power source to either charge the batteries, jump start the car, or power the car off of 110 when I am car shows. Being rearend would not be good but each battery is fused independatly and it is fused in the front of the car.
Old Nov 16, 2006 | 08:09 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Chad
Thanks for the response. These are excellent points. I can't begin to tell you how expensive saving money has been.
To your second point: does this apply to the LPE kit? That is, should extra bracing be applied before installation? If so, then I would pass. I had considered that very issue, but ***-u-med that LPE engineered it properly.
As to why do this, four reasons: better weight distribution, get the battery away from the computer, clean up the underhood appearance, and possibly make room for an Accusump. But as to the last, I don't really know if one can fit in that space. Anyone know?
To LPE battery relocation kits?
