Lets See You Audio
Old Nov 18, 2006 | 11:12 AM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
See pics
Old Nov 18, 2006 | 01:00 PM
diyguy's Avatar
diyguy
Originally Posted by beav626
I found a post somewhere on how to disable the brake bypass on the Jensen models...
I had to put a small switch on the grounding wire. There is a 2 second delay for any video to play. I just wait for the blue screen to come up then flip the switch, wait two seconds and flip it back. Wah-Lah - everything works just fine.
BTW - did you get the Soundgate adapter harness so your original Bose speakers will receive power? Found that to be a must, unless I wanted to replace and amp all the speakers.
Old Nov 18, 2006 | 05:25 PM
beav626's Avatar
beav626
I got the soundgate adapter... I have instructions that will allow you to by pass the switch all together I found this on the internet...
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
Old Nov 18, 2006 | 05:33 PM
Chief777's Avatar
Chief777
St. Jude Donor '15
Nothing to fancy, but here's mine.
Alipine HU 9857 to connect to and control my Ipod in my center console.
Focal Components in the doors
JL Stealth Box
600w Amp behind passenger seat. 150w to each door and 300 to the sub.
Old Nov 18, 2006 | 05:46 PM
wiz1500's Avatar
wiz1500
Insert the DVD
Region Code
Loader Version
Model Version
Region Code: 1
Brake Override ON
Macrovision: OFF
That is great info.....I just saved it.....Thanks...
Old Nov 18, 2006 | 07:16 PM
diyguy's Avatar
diyguy
Nice work in location a software fix! Gonna go try it right now!
Insert the DVD
Region Code
Loader Version
Model Version
Region Code: 1
Brake Override ON
Macrovision: OFF
Old Nov 20, 2006 | 11:40 AM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
Originally Posted by jay'szo6
Z06Joe:
Nice ride! The trunk is bad @ss. Where did you put your heater controls? And are those the anodized blue gauge pieces you've got? I always wanted to see them in a car.
Thanks!!! I put the ac controls in the glove box. Lengthend (if that's a word) all the wires and put in there. And yes those are the blue anodized gauges.
Old Nov 20, 2006 | 12:38 PM
vetterlatethannever's Avatar
vetterlatethannever
Originally Posted by wiz1500
I love the leather...
