Odd headlight issue... 9003 bulbs????
I take the bezel off and proceed to take the bulb out expecting to see two bulbs like it shows in the manual. to my surprise there was only one bulb and it was a 9003 bulb.
I bought this car from its original owner with 14000 miles. what do you think happend... he must have rewired it right... what would be the reason to rewire it to accept a 9003 bulb.
I have T85s (dip left). Its a single dual filament bulb that fits in a single housing.
It uses an H4 bulb for the low wattage fit and PIAA 135/90s for the high wattage mod.
The only mod I'd heard of up to now was the mod to fit 9005 bulbs (hi beam) into the low beam housings.
http://candlepowerinc.com/pdfs/H4_9003.pdf
"In 1991, automakers wanted to use H4 headlight bulbs on cars in the US, but the DOT decided engineering blueprints for H4 bulbs allow too much variance in the position of the filaments within the
bulb. So a new blueprint was made, with all the electrical and dimensional properties the same, but with stricter limits on filament placement variance. Because of the limits in the US on beam intensity in
effect in 1991, the maximum allowable light output tolerance was also reduced. This new bulb specification was called “9003/HB2”, because at the time, two numbering conventions were in use.
Many 9003/HB2 bulbs also carry the “H4” marking, and vice versa, because it is possible to meet the specifications in both blueprints at the same time."
Why would a dual filament bulb be fitted into a stock housing? Using stock wiring the low and high beam circuits are seperate; one connector for each. The Euro harness combines the two to give low and high on a single pigtail with a 3 way connector. It would need to be a one off lead to allow both filaments to light on the same low beam circuit retaing a seperate high beam function.
What housings do you have, stock or Euro? It sounds to me like you may have T84s fitted.
I bought this car used last year and it was bone stock... atleast thats what the original owner told me. The first poster told me he thinks he did the euro spec headlight swap.
I know the housing only houses one bulb and the wiring is all wired up for one 9003/h4 bulb in each housing. I am going to take a closer look tomorrow to see if the actual lenses are glass.
I am pretty sure the original owner did the euro swap.
changing the bulbs is a pain in the ***... any tips on changing the bulbs. someone told me that the headlight have to be half way up... i honestly dont see how that helps with the bulb swap.
Stock lenses have a housing for each bulb (hi 7 lo) and are plastic. You can see from my pic above that the Euros have the single housing with the dual filament bulb. He probably fitted the harness as well which plugs in at the passenger side and takes the low bulb power feed and splits the funtions out into low and high beam.
Raise your headlamps via the switch on the stalk, with headlamps raised and on, turn the stalk to the parking lamp position. The headlamps will remain up, the headlights will go off, but the parking lamps will remain lit. Don't worry about those, they will go off in about 10 minutes automatically.
There are three phillips screw heads that hold the black surround bezel. One on the outboard side and two on the inner side. Remove all three screws. Carefully raise the hood, make sure that the bezels are not in the way of the hood when it opens. To remove the bezel pull gently from the upper middle above the headlamp (it slides into a clip above the headlamp), pull the upper part out about an inch and push down on the lower left and right corners. The bezel will drop right out.
This next part is optional, but if you have big arms it will help. There are two hood supports with black bumper stops located just inboard of each head lamp. They support the front lip of the hood. They have a black bumper on top, and threaded bolt into the front facia. Mark the location of the locking nut with a pencil or pen. Back off the locking nut and remove the bolt/bumper. Once removed its a clear shot to the rear of the headlamp assembly. Before removing the bulb, take a look at the current connectors placement, this will help ensure you put the new bulb in correctly. Change out your bulbs, make sure you don't touch the new bulb glass, wear latex gloves if necessary.
Put everything back together, check for proper alignment. (if possibile, before you remove the old lamps, you might want to mark on the garage wall, or door your current headlamps light pattern with masking tape to verify same pattern after installing the new lamps)
Good luck, take your time and you should have this done in less than an hour.
Euro
Stock
Its doable but its a PITA. You could always loosen the mounting bolts if you have thick arms. I can just about do it but its tight.
I agree that taking off the black plastic housing is essential.
Euro
Stock
Anyone know how long a hid bulb last?
